Thread: Switchback Turn Signal Help
Results 1 to 12 of 12
  1. #1 Switchback Turn Signal Help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    I recently put some switchback LEDs in my turn signals and I put in a new ep28 relay in the middle spot to fix the hyper flash problem BUT when my running lights are on (switch in the up position) the white LEDs are on (like there supposed to) and I go to use the turn signal the white LEDs don't turn off only the amber ones flash, I thought it was supposed to switch between white and amber?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Switchback Turn Signal Help
    Yoga city
    did you try switching them around in the housing? Did you turn the parking lights on? DId you put the old relay in and see if they the white turns on at least?
  3. #3 Re: Switchback Turn Signal Help
    Oct 2011
    Michigan
    If I switch the bulb around it doesn't work at all, with the parking lights on and using the turn signals the white lights are always on, with the old relay it hyper flashes
  4. #4 Re: Switchback Turn Signal Help
  5. #5 Re: Switchback Turn Signal Help
    Oct 2011
    Michigan
    That's what I think happened too oh well they were only $7 and still look good as white running lights
  6. #6 Re: Switchback Turn Signal Help
    some sets leave the white on while the amber flashes, other sets don't.
    i have the other kind. the amber flashes and no white is on.
  7. #7 Re: Switchback Turn Signal Help
    Oct 2011
    Michigan
    Yeah how much did you pay for those?
  8. #8 Re: Switchback Turn Signal Help
  9. #9 Re: Switchback Turn Signal Help
    Ohio
    A good pair is gonna run you 20+ a bulb.
  10. #10 Re: Switchback Turn Signal Help
    Oct 2011
    Michigan
    Not worth it haha
  11. #11 Re: Switchback Turn Signal Help
    Ohio
    Figured
  12. #12 Re: Switchback Turn Signal Help
    Quote Originally Posted by asite57 View Post
    Not worth it haha
    for good bulbs, yes it is.
  1. Turn signal
    By penguinknot in forum General Tech Discussion
    Last Post: 09-11-2011, 04:46 PM
  2. turn signal help
    By sUpErClEaNbLaCkMaChInE in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2011, 08:09 PM
  3. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
