Thread: tail and dash light problem
Results 1 to 10 of 10
  1. #1 tail and dash light problem
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    my tail lighs are not working nor is my dash... also i can turn on my high beams by turning the dimmer swith all the way to the left
    .. this all of a sudden just happened.... also my door dinging is staying on with the key out and lights off help... thankx
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: tail and dash light problem
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    Sounds like a ground wire problem check your harnesses some of the wires might be exposed
  3. #3 Re: tail and dash light problem
    brunswick
    wiring where... where to start
  4. #4 Re: tail and dash light problem
    Jan 2012
    Philadelphia
    did you check all the fuses?
  5. #5 Re: tail and dash light problem
    brunswick
    Number 37 under hood blew replaced it and blew again like a second after lights were turned on
  6. #6 Re: tail and dash light problem
    Jan 2012
    Philadelphia
    check for water in the tail lights or headlights happened to me and my friend in his 00 special edition one night while we were driving thats all it was, the same fuse blew as you and kept blowing out and we checked the tails and emptied them replaced the fuse again and it was good
  7. #7 Re: tail and dash light problem
    brunswick
    water somewhere on pass head light.. i un hooked it and fuse didnt blow
  8. #8 Re: tail and dash light problem
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    This problem just happen to me yesterday
  9. #9 Re: tail and dash light problem
    brunswick
    as stated above check all lights for water..
  10. #10 Re: tail and dash light problem
    May 2011
    El paso tx
    I well tomorrow when I get a chance thanks
  1. Headlight and dash light problem. Please help!
    By steeck1 in forum General Tech Discussion
    Last Post: 09-28-2012, 11:43 PM
  2. tail light problem
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 07-05-2012, 10:25 PM
  3. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  4. Headlight/Tail light problem
    By SwatRaptor in forum General Tech Discussion
    Last Post: 01-25-2011, 08:19 PM
  5. tail light problem
    By RyanL in forum General Tech Discussion
    Last Post: 11-09-2010, 10:41 PM
