Thread: tail light problem
Results 1 to 9 of 9
  1. #1 tail light problem
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    I have a problem that whenever I step on the breaks or use my left turn signal the left signal is much dimmer then the right and third break lights. I am thinking it might be a ground issue but I do not really know where to start on this one. advice would be much appreciated.
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: tail light problem
    GTP Level Member simbah's Avatar
    Lala land
    Could be a bad turn signal switch, common problem in W- Body cars.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: tail light problem
    Nov 2008
    ok. What if it also is dim with brake lights?
  4. #4 Re: tail light problem
    Lala land
    Bad turn signal switch can cause this problem also, I know it sounds funny but it is true.
  5. #5 Re: tail light problem
    GTX Level Member blackflag's Avatar
    Virginia
    Good info! I'm going to switch mine out and see if it helps my dim brake lights
  6. #6 Re: tail light problem
    the bulbs over time get a burnt look to the glass, its on the inside of the bulb. that could be why your are dim. pulse the bulbs just get old, and dont burn so bright.
    when ever one burns out, i change both bulbs. i keep the good one for a spare if im caught with a dead one down the road.
  7. #7 Re: tail light problem
    Nov 2008
    where is said turn signal switch and are they reversible?
  8. #8 Re: tail light problem
    the switch in on the other end of the stick you move to turn the blinkers on.
    you need to take the plastic around the column off, un bolt it. un hook the harness under the dash, and then take the harness out, reverse for install.
    make sure the one you get has all the same functions that you have, cruise, wipers, delay, or it wont work.
    and this part is not cheap, used they run about 75.
  9. #9 Re: tail light problem
    Nov 2008
    I found another detail that Interests me. when I lock my car the lights are both bright on both sides. Could it still be the turn signal switch?
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. Headlight/Tail light problem
    By SwatRaptor in forum General Tech Discussion
    Last Post: 01-25-2011, 08:19 PM
  3. tail light problem
    By RyanL in forum General Tech Discussion
    Last Post: 11-09-2010, 10:41 PM
  4. tail light fix
    By skidoojames151 in forum General Tech Discussion
    Last Post: 08-26-2009, 12:31 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
