Thread: Debadging Help!!
Results 1 to 17 of 17
  1. #1 Debadging Help!!
    SE Level Member Bessesen2's Avatar
    Jul 2012
    Livonia,MI
    I started to debadge my GP on the trunk lid. Is is supposed to take 20-30 minutes?? I am using fishing line to cut off the badge and using adheseive remover to remove the glue. Is there somthiing else i am missing or am i good?
    1999 Grand Prix GTP. 157xxx miles and climbing everyday.
    Indiana
    A heat gun helps to loosen the glue. But yeah, it'll take some time.
  3. #3 Re: Debadging Help!!
    I just use my man hands and pull really hard lol
  4. #4 Re: Debadging Help!!
    The Boss Iceman6669's Avatar
    Jun 2011
    Use a hair dryer.. A heat gun can get hot enough to harm the paint...
    I used a hair dryer and some fishing line... Went pretty quick.. Then after it came off I used rubbing alcohol and got all the adhesive off. Then I waxed the BAjesus outta it.
    2011 F-150 Yote powered
  5. #5 Re: Debadging Help!!
    Jul 2012
    Livonia,MI
    Is the rubbing alcohol better then aadhesieve remover?
  6. #6 Re: Debadging Help!!
    Its about the same. I used goo gone.
  7. #7 Re: Debadging Help!!
    Ontario
    I'll tell you the easiest way. It took me 5 minutes per badge. All you need, is a hair drier, floss and polishing compound. Heat the thing up for a minute or two, take floss, cut the glue, take polish while glue is still warm and micro fiber towel, BAM. All gone and all done. Easy peasy. Results speak for themselves.
  8. #8 Re: Debadging Help!!
    Jun 2012
    United States
    spray wd40 on the adhesive and let set for like 30 sec then it will wipe right off. I have done it a bunch, and works everytime on any decal or sticker. Just make sure when your done rinse it wit soapy water to get off the wd40
  9. #9 Re: Debadging Help!!
    GT Level Member TJeno's Avatar
    Jun 2012
    Ames, Iowa
    I'm going to go do this right now, but I don't know if fishing line would work on the dealership sticker..what would you guys recommend for that?
  10. #10 Re: Debadging Help!!
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by TJeno View Post
    Heat up the badge and just pull on it gently. You can use something that is plastic and soft enough so that it doesn't scratch your paint. GooGone works great for the left over adhesive.
  11. #11 Re: Debadging Help!!
    razor blade and a steady hand.
  12. #12 Re: Debadging Help!!
    Jul 2012
    Livonia,MI
    took me like an hour but i finally got all the badges done! The hairdryer helped a lot!
  13. #13 Re: Debadging Help!!
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Any ideas on how to get the decails from the back where it says Pontiac off? The person I bought it from liked yellow and I want to make it black reflecting ehite
  14. #14 Re: Debadging Help!!
    Houston
    If you're talking about inlays, just heat them up and use a blade to poke them and peel them off.
  15. #15 Re: Debadging Help!!
    plasma cutter will work too.
  16. #16 Re: Debadging Help!!
    Houston
    Indeed.
  17. #17 Re: Debadging Help!!
    Jun 2012
    Illinois
    Okay thanks! Just got to get my hands on a plasma cutter...
  1. Debadging?
    By betz in forum General W body
    Last Post: 03-28-2012, 08:04 PM
  2. debadging?
    By jcmonteman in forum General Tech Discussion
    Last Post: 04-03-2011, 10:18 PM
  3. Regarding debadging....
    By DSharp in forum Detailing Tips and Tricks
    Last Post: 01-08-2011, 01:36 AM
  4. Question on debadging
    By MakeitLouder97 in forum Visual/Body Modifications
    Last Post: 08-05-2010, 01:31 AM
  5. debadging?
    By nicksilvergt99 in forum The Rant Forum
    Last Post: 08-14-2009, 09:32 PM
