In 99 the VATS system worked like this.
Key on, fuel pump primes and the injectors flow a little fuel into the cylinders
Crank, engine starts and burns the prime fuel, but fuel pump and injectors are not turned back on. Then the car stalls.
A stall after about 10 minutes that won't restart until the engine begins to cool is likely a crank position sensor, ICM or MAF
