Thread: swapping l32 into 99gtp
Results 1 to 5 of 5
  1. #1 swapping l32 into 99gtp
    Apr 2011
    United States
    I might get a complete l32 motor and trans from a newr gtp, should this bolt right in aslong as i keep my original sensors and accesories
    I hear the motor and blower are better, are the transmisions anything better or same thing, and can that be swapped as well
  2. #2 Re: swapping l32 into 99gtp
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    You will have to swap the oil pan or grind out a bit of your cradle to get the aluminum oil pan to clear it. You wont be able to use the trans because of the difference in the PCM i think. But the block and accessories should be good to go.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  3. #3 Re: swapping l32 into 99gtp
    Apr 2011
    United States
    Back on board with this,since i think my motor is on its way out, what else would i need to do for this to work, would i need to switch throttle bodies and get an adapter, can i leave the l32 lim on
    And if i do a cam, should i put a differnt timing chain/ pushrods in there
  4. #4 Re: swapping l32 into 99gtp
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Youll need an L67 throttle body and adapter. Also either use l67 injectors, or have to buy injector adaptors, as connections are not the same. The L32 LIM will be fine. Depending on which cam you deside on, will dictate what chain youll want to run. IMO S1x, jp single roller,new tensioner,Intense o.r. pushrods. It will be reliable, without having to take front cover off yearly to inspect chain like the double roller
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  5. #5 Re: swapping l32 into 99gtp
    Apr 2011
    United States
    Ya thats actually what i was thinking, i like the sound of the s1x, but not sure sure about jp racing chains cause i know they are made out of the country and there have been some chain failures in the lsx engines with their double roller chains
    Is there any other good chains out there
  1. trade firebird for 99GTP
    By Bigthoogs in forum Off Topic Discussion
    Last Post: 04-13-2011, 10:17 PM
  2. 99GTP vs new charger,BMW325ci
    By Leo Nahlik in forum Track Sessions and Kills
    Last Post: 09-12-2009, 12:47 AM
  3. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  4. 99GTP vs. 02 Audi TT
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 06-30-2008, 11:26 AM
