Thread: Customization Help Needed.
Results 1 to 16 of 16
  1. #1 Re: Customization Help Needed.
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by BADAZGTP View Post
    With your painting, just make sure you prep good. And when you start spraying, use light even coats. Don't try and cover it all in one shot. Even if it takes you 5 or 6 coats to get it covered good, it's better than having runs. Also, allow good drying time in between each coat, that way by the time the last coat dries, it will be dry all the way through. If you don't, the bottom layers can still be wet with the outside feeling dry and you can end up with finger prints in the paint. For protection, throw about 3 or 4 coats of clear on it.
    If you want to tacle the headliner yourself, it's not as hard as it looks. When you get the old material off, get some sand paper and get all the old glue off. Then cut your matetial to where you have about 5 inches of over hang all the way around. Spray the whole headliner with glue and let it tack up for about 5 minutes. Then starting in the center and working towards the back of the board, spray the back of the materialand gently apply pressure at the center working you way to the sides to keep from getting any wrinkles. Do this all the way to the back and then to the front. once it's done, let it sit for a few hours to tack really good and then you can go back and trim all the excess and cut any holes. Let it sit for a good 24 hours and then you can reinstall in the car. Just take your time and be patint with it and you'll have no problems. Just don't put to much pressure when applying the material or the glue will soak through and you'll have hard spots or you'll end up with indentions in it. If you have any questions once you get started, I'll help you anyway I can. I am pretty much on here 24/7. Good luck with it.
    I'm gonna need to go shopping for paint in a couple of days. Also I'm thinking of just wrapping the material over the original headliner in case I wanna take it off. Like stapling it, would that be okay?
    *sig is too tall*
  2. #2 Re: Customization Help Needed.
    Apr 2008
    Chillin at the Beach , VA
    Quote Originally Posted by Dboy23 View Post
    I wouldn't staple it, you'll have more problems than what it's worth and would look pretty tacky. You won't have the form of the head liner and would look half @$$ed. Good thought though, but just won't work like you would hope. If you want to do it, go ahead and do it the right way, you'll be more pleased in the end. But, that's just my opinion.
  3. #3 Re: Customization Help Needed.
    GT Level Member stkks's Avatar
    Annandale, Virginia
    Here is the replacement list from Sylvania alon with their website:
    http://www.sylvania.com/ConsumerProd...RG-Results.htm
    2004 PONTIAC Grand Prix
    Low beam headlamp
    9006
    9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
    9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
    9006XV XtraVision Halogen - The Brighter Light
    9006CB Cool Blue Halogen - The Whiter Light
    High beam headlamp
    9005
    9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
    9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
    9005XV XtraVision Halogen - The Brighter Light
    9005CB Cool Blue Halogen - The Whiter Light
    Parking light
    3757ALL
    Front turn signal
    3757ALL
    Rear turn signal
    3057
    3057LL Long Life Upgrade: Up to twice the life of the standard lamp
    Tail light
    3057
    Stop light
    3057
    High mount stop light
    Assembly
    Fog/Driving light
    898
    License plate
    194
    194LL Long Life Upgrade: Up to twice the life of the standard lamp
    Back up light
    3157LL
    Front sidemarker
    194
    Rear sidemarker
    194
    Glove box
    194
    Map light
    2825LL
    Autopage Alarm w/Remote Start-35% Tint-SPO Tips/Grills-GMPP RTAs-F/R STBs w/Don's brackets-SilverStars H/L Beam-DHP PCM-CORSA-Thrasher CAI-Class II Receiver Hitch-AVS Vent Visors/Tailshades-Chrome Side/Engine Supports-180T-stat-3 AeroForce Gauges-MSD Coils/Wires-NGK TR-55IX
  1. CarFax Needed
    By JJ91284 in forum Off Topic Discussion
    Last Post: 07-02-2008, 11:42 AM
  2. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
  3. Replies: 5
    Last Post: 04-08-2008, 02:28 AM
  4. When is the Non-HD to HD Trans Upgrade Needed
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2008, 03:53 PM
  5. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
