the Spyder LEDs have a box with a built in resistor, are the plugs plugged in the correct direction? and i dont think it would be ground as you are getting power, if you had a bad ground, it wouldn't come on at all (parking lights nor brake lights) i would just try to turn the plug back around and see what you get, if you have parking lights not working on the front, then there is a completely different problem
