Thread: Air Box Delete and take out
Results 1 to 20 of 23
  1. #1 Air Box Delete and take out
    Mar 2012
    United States
    On a Stock 98 GT, Would I b able to take the Air Box out and run just the air tube with K&N Air Filter in it till I get better tube. Is it safe to take the air box out because I heard the PCM is under the box and will get damaged. Will the PCM get damaged or no.
  2. #2 Re: Air Box Delete and take out
    Portland Oregon
    No damage will occur to the PCM. Go ahead and read the safely modding your 3800 thread. It'll cover a lot of basics for you.
  3. #3 Re: Air Box Delete and take out
    Bunnell, FL
    the pcm actually sits in the airbox. but some get the 00 blazer pcm tray, some zip tie it, and others just let it free float. txslow6 actually has his in a very unique way
    I'm a Sex Offender
  4. #4 Re: Air Box Delete and take out
    Sep 2011
    Logansport, IN
    And save yourself a chuck of money and buy a Spectre Filter.......they are actually better quality then a k&n POS
  5. #5 Re: Air Box Delete and take out
    Mar 2012
    Centerville, OH
    I am also getting ready to start the process of removing my air box for one of the custom made cold air intakes like in the how to write-up on the custom intake and pcm mount. I have a 2004 GP GT1, and I was wondering if anybody could explain how to get the IAT sensor into the into the 4" 45 degree mandrel a little better (since this is where the write up got a little fuzzy for me) or if you have a better way to install the IAT sensor please let me know.
  6. #6 Re: Air Box Delete and take out
    SE Level Member HiLuckyB's Avatar
    Romulus, MI
    I just installed this 3.5" PIPE PONTIAC GRAND PRIX SE GT GTP 3.8 3.8L V6 AIR INTAKE 97-2002 2003 BLUE | eBay on my 1998 GT. Not bad for $27
    Ignore the dirty engine bay Just got the car from my uncle, And she needs alittle work.
    1998 GT Coupe
    MODS- Overkill Tune- ZZP 3" 304SS Catless Downpipe- Transgo Shift Kit- 180 T-Stat- Taylor 8mm Wires- Ebay Air Intake- Flipped Motor Mounts
    Ordered- Desert Fox Transmission Cooler
  7. #7 Re: Air Box Delete and take out
    Yoga city
    we got the same one!
  8. #8 Re: Air Box Delete and take out
    Mar 2012
    Centerville, OH
    Quote Originally Posted by Jteske88 View Post
    How did you remove the tray under your airbox?
  9. #9 Re: Air Box Delete and take out
    Quote Originally Posted by GP24 View Post
    3 bolts under the pcm.
  10. #10 Re: Air Box Delete and take out
    Sep 2011
    Copperas Cove, TEXAS
    LOL, I have the same Hot Air intake as those 2 post above, yup $27 w/free shipping and 3.5inch pipe works just fine. Also the cone filter holds down my pcm from moving.
  11. #11 Re: Air Box Delete and take out
    Yoga city
    I yelled about shipping and gave them a nuetral rating, they sent credited
    me 10$ and asked if I would change the rating so 17$ for me!
  12. #12 Re: Air Box Delete and take out
    Bunnell, FL
    cut a slit in the rubber connector and insert the iat
    poof it's just a cone now
    I'm a Sex Offender
  13. #13 Re: Air Box Delete and take out
    Yoga city
    If your telling that to me I inserted before it was fully assembled
  14. #14 Re: Air Box Delete and take out
    Sep 2011
    Quote Originally Posted by z3r0 View Post
    I had a spare specter filter I did that to, but I like having the polished tube with grommet made for the IAT. Either way I think is good. Love hearing that SC or if N/A moar roar.
  15. #15 Re: Air Box Delete and take out
    Bunnell, FL
    you kinda get the idea
    so glad i found a black filter
    I'm a Sex Offender
  16. #16 Re: Air Box Delete and take out
    Texas
    I opted to put my PCM in the bumper:
    However, I have run the PCM in the engine bag unbolted before. And other times I have run the PCM with zipties. It will be fine which ever route you go.
    85 Corvette
    01 TA
    03 Z06
  17. #17 Re: Air Box Delete and take out
    Mar 2012
    Centerville, OH
    Please note this is my first time doing this. So, I removed my air box this weekend and installed a open cone cai filter on the end of the hose that has the sensor thats connected to the flex tube. After looking at pics of other forum member's CAI I began to question why did people remove the flex tube thru airbox. I was trying to find a 3.5" diameter metal pipe locally, but all the auto part store here only had 3" diameter mandrels (which were made of some type of plastic), so I opted to just get a long open cone air filter and attach it to the piece that connected to the air box. Does connecting a mandrel to the throttle body with a rubber coupler provide better performance... How did you all get this sensor (circled below) to seperate from the hose and fit into that circular hole on the mandrel?
  18. #18 Re: Air Box Delete and take out
    Mar 2012
    United States
    I will do something like that and Thax to all the ideas.
  19. #19 Re: Air Box Delete and take out
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    That is exactly what I did ! check out my post and pics on the thread custom intake and pcm , I cut the stock box in half by the part where is glued together zip-tied it back into the body and laid the pcm on top l. I zip tied the cone to the fender-well (there is many areas you could ziptie to make sure it doesn't move like crazy)
  20. #20 Re: Air Box Delete and take out
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    To answer the first part of your question i have heard that it helps a little to get rid of the flex tube because the ridges will cause the air to not flow as good as a smooth inside.
    As for the answer to how to get the sensor out I cant help you there. I have yet to do this myself but will be doing it shortly.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  2. delete please
    By putskijr in forum Off Topic Discussion
    Last Post: 11-23-2009, 05:56 PM
