Thread: Want to paint my engine cover... how should i do it?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Want to paint my engine cover... how should i do it?
    GT Level Member GrandPrixGT00's Avatar
    New Jersey
    i sanded mine down started with 400 grit worked up to 2000 grit trust me it wasnt fun i did it by hand took all day then i cleaned it on day two used dawn(that cuts grease) on the heat pad that is on the bottom and washed it out with the hose then after letting it dry (i used a blow dryer to speed it up cause it started to rain that day) next day it was 100% dry i used 3 coats of gloss black rust o'leum then 3 coats of engine enamel (clear coat) ill put up pics but its pourin today ill try and get out there i think it came great i painted my fuse box the same but i didnt sand it just cleaned it with soap and water and it came just as good. Also any paint i use on my engine bay or for anything under the hood is high heat
  2. #22 Re: Want to paint my engine cover... how should i do it?
    New Jersey
    When i got it from the junk yard
    3 weeks later (today)
  3. #23 Re: Want to paint my engine cover... how should i do it?
    London Ont, Canada
    I have a 3.1L - it doesnt have a cover possible does it?
  4. #24 Re: Want to paint my engine cover... how should i do it?
    New Jersey
    na i dont think it does
  5. #25 Re: Want to paint my engine cover... how should i do it?
    New Jersey
    i was expectin feed back on my paint job on the engine cover .....tough crowd tough crowd
  6. #26 Re: Want to paint my engine cover... how should i do it?
    London Ont, Canada
    Quote Originally Posted by GrandPrixGT00 View Post
    its black - its well painted, but black. I think you should give it some detalis to make it stand out.
  7. #27 Re: Want to paint my engine cover... how should i do it?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    my car is a silver mist so i was wondering if it would look cool if i painted the body of the plastic silver like the car and then the lettering black. does that sound like a good idea? also is the high temp really necessary for this or will the krylon stuff work just fine?
    silver 2003 Grand Prix GT List is on it's way to be updated
  8. #28 Re: Want to paint my engine cover... how should i do it?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Use high temp. Trust me, the top of ur engine gets hot on that engine cover. silver/black, sounds Ok. its nothing special, will probably look better than stock.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. how to paint your engine cover, fuse box, plastics [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 07-09-2010, 01:28 AM
  2. Stupid quetion about engine cover
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 08-17-2008, 01:01 AM
