Thread: 97-03 Tinting Tail Lights Except Reverse White Light
Results 1 to 12 of 12
  1. #1 97-03 Tinting Tail Lights Except Reverse White Light
    Jul 2011
    Los Angeles
    Anyone tried this? Did the results come out good? Thinking about doing that, i dont think Flip has done it yet
  2. #2 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Nov 2008
    Waterloo, Iowa
    I think there is a tail light tinting thread in here that has pics of it. As well as the reflector left untinted.
    Both look awful, tint the whole thing and get some high intensity or LED reverse bulbs.
    Ohio
    Look for my thread in the visual section. It's called tinting tails, anyway I did this on my buddy's forte. It looked nice. On a gp, I've never done it but idrk how it'll look. I think they look better with full tint but do whatever you think looks good. After all it is your car, not ours if you have any tint questions, shoot me a pm
    Bunnell, FL
    Get them tinted with everything done run hids. Like I do for reverse
    Android Fire
    I'm a Sex Offender
  5. #5 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    you cant rely on your reverse lights to see anyway. anyone that does hasnt learned how to drive a car yet.
  6. #6 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Kansas
    Especially in a W-body.
  7. #7 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Yeaaaaaa they dont do anything in my car.
  8. #8 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Mine are blown cause they just fill with water and rusted out the sockets so it shorts out the new bulbs intently
    SMGPFC Member #10
    Jul 2011
    Los Angeles
    Well it's just for show in not really doing it for seeing, here in ca la area cops are a bit strict even though in the end it depends, but we can get away with tinted tails but leave the white alone. It's def illegal to have them tinted it's just depends how ur tint is justified, like if ur lights are still visible and give out a red light and a white reverse we are good.
  10. #10 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Nov 2008
    Waterloo, Iowa
    LED reverse bulb man. That'll power through it just fine.
  11. #11 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    Bunnell, FL
    i wonder how mine will be. should be bright as fukt
    I'm a Sex Offender
  12. #12 Re: 97-03 Tinting Tail Lights Except Reverse White Light
    tape off the white reverse lights with auto painters tape, like this.
    while the tint spray was still wet i took off the tape, and cleared over everything.
    this is 2 coats of tint, 5 coats of clear, sanded, and hand compounded and waxed, there are still very fine scratches, see only if you are looking for them from sanding, but the porter cable will fix that in due time. 2 coats will cherry them some, 3 will make them black, be careful how much you use, aka how slow or close you are with each pass.
    and the reverse lights at night. that were taped off before tinting. stock bulbs.
    takes 2 days to do it right, one day of sanding prep and painting and leaving it to set over night or 24 hours, then re wet sand and buff till your arms hurt some.
  1. Tinting; tail lightsonly or headlights as well?
    By mousemonster1232 in forum Visual/Body Modifications
    Last Post: 02-28-2011, 12:05 AM
  2. Tail-Lights Tinting [*]
    By John02Hawk in forum How To Write-Ups/Tech Tips
    Last Post: 07-08-2010, 01:09 AM
  3. Reverse shifter position shorting the tail lamp fuse
    By itfrg in forum General Tech Discussion
    Last Post: 02-27-2010, 04:55 PM
  4. Tail Light Tinting With VHT simple and perfect Guaranteed
    By pissedoff02grandprix in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2009, 03:00 AM
  5. tinting tail lights???
    By kingd44 in forum Visual/Body Modifications
    Last Post: 04-09-2008, 03:19 PM
