Thread: HID problems :(
Results 1 to 3 of 3
  1. #1 HID problems :(
    Oct 2011
    Colorado
    Alright so I have a 1998 grand prix gtp, and I ordered HID's from HidHeadlightKit.com, the bi-xeon ones for high and low beams. First off, when I have low beams on the light is lighter than when I turn on high beams. Thats not so bad, but I also noticed that my dual climate control lights pulse when ever the hid's are on. If I dim down the lights on the inside then it will stop pulsing. Any ideas????
  2. #2 Re: HID problems :(
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    you must have hooked something up backwards. check all youre connections and double check the install directions. also you may want to have the alternator tested as the bristles may be worn down and not generating electricity at the same rate as in its newer days. hope this helps.
  3. #3 Re: HID problems :(
    Kansas
    Relay harness?
  1. hid problems
    By jspangler22 in forum Visual/Body Modifications
    Last Post: 05-13-2011, 05:29 PM
  2. Problems with the GTP
    By DaL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 02:21 PM
  3. New guy with a few car problems......lol
    By jigwynn in forum Introductions/Noob Questions
    Last Post: 04-24-2010, 10:58 PM
  4. 1 and 2 problems
    By Tony in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-22-2010, 06:50 PM
  5. problems problems problems!
    By NomeCrusher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2009, 03:26 PM
