Thread: GTX Hood Install
Results 1 to 9 of 9
  1. #1 GTX Hood Install
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I'm pretty mechanically inclined. I've gutted my interior and put it back together with an upgraded I/P wiring harness. Changed hubs and rotors. A lot of engine work. All by myself. Am I deluding myself in thinking I can install my new GTX hood by myself?
  2. #2 Re: GTX Hood Install
    its gonna be hard by yourself, but its pretty easy with two people. just takes a few tries at it to get it lined up perfectly.
  3. #3 Re: GTX Hood Install
    its AWDsome JarenSTi's Avatar
    Hawaii
    what he said. it would be hard to get it attached with only one person.
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  4. #4 Re: GTX Hood Install
    that's a 2 person job for sure, even removing a hood by your self can result in a cracked windshield. both people should keep one hand wrapped/holding around the corners of the hood when installing or removing to help prevent it slipping and hitting the windshield.
  5. #5 Re: GTX Hood Install
    Lakeside Park, KY
    Well, my windshield is already cracked, so I'm not worried about that. My GP has the prop rod, so I was thinking that would help me get it on by myself. I was gonna put some rags in the corners and prop it up with the rod while put the bolts in. I'm thinking I would be better off getting some help now.
  6. #6 Re: GTX Hood Install
    youre definitely better off having a friend help you for the 10 minutes it takes to do it.
  7. #7 Re: GTX Hood Install
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    yeah get som help you dont want to damage the corners on the hood. It would be easy chip the front corners if you dont have help
  8. #8 Re: GTX Hood Install
    Lakeside Park, KY
    Well, as I said before, my GP has the prop rod. My new hood had the "nipples" for the struts. I was gonna grab a set of hinges front the junkyard, but they seem to be either riveted or spot welded to the fender. Is there anywhere that sells the "nipples" that I could install? I like the struts for quick access, but I would use the prop rod for longer stretches.
  9. #9 Re: GTX Hood Install
    SE Level Member morrisgl's Avatar
    Virginia Beach, VA
    I removed my factory hood and installed a SD hood all by myself. No problems.
    Gary Morris
    2001 Grand Prix GT
    Bronzemist Metallic
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Hood Liner or no hood Linar?
    By Taz Magister in forum General Tech Discussion
    Last Post: 02-21-2011, 11:06 AM
