Thread: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
Results 1 to 20 of 21
  1. #1 Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Fayetteville, AR
    This How To write-up on Installing Heat Extractors On A Stock Hood has been added to the HOW TO section and can be found HERE.
    Bastard Reptile's Avatar
    Kansas City, MO
    You sir....are my hero.
    Fayetteville, AR
    haha, anytime Reptile. if you have any questions along the way or if there's anything i can do to help just let me know
    Kansas City, MO
    I think you pretty much answered any questions I would have had. I've got an Anniversary hood and louvers, I just didn't want to go through the pain of matching the paint. If I can just do this, I'll be happy...and I can just sell the hood that I have.
    GT Level Member flynn's Avatar
    Overland Park/Topeka, KS
    Quote Originally Posted by Reptile View Post
    What color is the paint on the hood?
    Signatures suck!
    Kansas City, MO
    It's a bare brand spanking new hood. Never even made it to the assembly line.
    Oklahoma
    You are a whole lot more brave than I am. I wont even bend my fender well brace to put in a FWI and your on there marking up your hood, cutting and drilling, my hats off to you sir.
    Great How to.
    Fayetteville, AR
    yea, i was on edge the whole time. There is still a "fitment" issue or two but since you have a hood that already has the holes cut in it from the factory, you'll be okay. And anyone else who happens to stumble upon this write up, if Whitcomb has made it over to this forum yet, he's the guy to talk to about getting a hood that's already cut from the factory or he might be able to just get you a set of extractors, i dunno. I think the stealership charges $1000 for just the hood, doesn't even include the extractors(scoops). Those are $250 apiece from the stealership. So, yeah, anthony whitcomb is the guy to talk to if you dont wanna get price raped
    Kansas City, MO
    Well, once I get the car out of the way, I can make exact measurements and such. I just don't want to go through the price of paint an labor. While I may be able to do all of it myself, my current hood matches my car...I'd be upset if I ended up painting it several times to get the color to match.
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    Congrats on this Mod. You are much braver than I to have cut into the hood that way. Trust me I looked at mine for probably a year before I had a shop do it for me instead. I just couldn't bring myself to do it with no prior metal work (however that hadn't stopped me from cutting a hole in my dash for my HUD).
    One question for you , did you get the drip tray that goes underneath the hood? The tray kinda locks onto the underside frame work of the hood and then from there you could drill the holes for the pegs on the vents. It seems like it would be an easier way to line the vents up.
    This is at least what I was planning to do for mine. However like I said, I didn't actually do it so I don't know how well this method works.
    Just throwing it out there.
    Drew
  11. #11 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Port Hope Ont,Canada
    Brave..
    And thanks for a great write up
    John
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  12. #12 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    i iwsh i had the balls to cut into my hood like that!!!
  13. #13 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    i've got the special edition and i've had paint issues with those damn heat extractors. if it didn't look so damn sexy i would have sold the hood but instead i convinently got in a fender bender where they had to repaint it anway . i'm not a paint expert, but make sure you use proper prep when painting those plastic extractors.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  14. #14 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Feb 2010
    TN
    Quote Originally Posted by Quicksilver_GP View Post
    where'd you get the extractors?
  15. #15 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Feb 2013
    Missouri
    Sorry about bringing this back from the dead, but the link in the first post is dead for me, anyone have another link?
  16. #16 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    I was also looking for this and now I'm sad because its gone
  17. #17 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Jefferson City MO
    Just out of curiosity, has anyone tried contacting the original poster?
  18. #18 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Feb 2013
    Missouri
    Not yet, mainly because of this:
    Last Activity06-12-2009
  19. #19 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Mar 2012
    Minnesota
    I did this on my '99 GT. It's not that scary really. Mark out and measure the extractors. I traced the part that goes into the hood then trim about and extra 1/2" on the bottom and top part and 1/4" on the side and then used 3M tape to hold the extractors on as well as the drip tray
  20. #20 Re: Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Is there any possibility of you can give dimensions on where to install the heat extractor?
    Quote Originally Posted by ColeTrain84 View Post
  1. Seat Swap: 04+ to 97-03[*]
    By LowlyfeGTP in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2013, 03:32 PM
  2. Custom Paint Your Hood Liner [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 08-10-2009, 09:35 AM
  3. my new hood and spoiler!
    By kyle99gtp in forum General Tech Discussion
    Last Post: 04-18-2008, 10:47 PM
  4. New Hood
    By J_Ferguson in forum Visual/Body Modifications
    Last Post: 01-21-2008, 02:23 AM
  5. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
