Ok here's my problem. I installed my 35w 9007 HID kit from VVME yesterday. I am using a relay harness and its single beam only. Everything is plugged in the way its supposed to be. When I start the car up and turn on the lights everything turns on just fine. If I turn the car off and try turning on my headlights, the drivers side headlight flickers for a split sec then goes off. It almost seems like there isnt enough power going to it. I tried putting my battery jumper on the battery then trying to turn the headlights on with the car not running and it didnt change anything. I know the ballast and bulbs are fine because I swapped them with the passenger side which always works whether its running or not and it still wouldn't work on the drivers side. I even disabled DRL by unplugging it and it didnt change anything. Ive cleaned up and redid all the grounds on the car including the new grounds used for the two HID kits that ive installed and that didnt help. Ive tried new locations for the ground, and that didnt help.
I have 35w 880 HID fog lights from vvme installed too, don't think that matters but I thought I would add that info.
Why does the drivers side HID light not turn on when the car is not running? This problem is driving me nuts ! If anyone can help please let me know, thanks !
