Thread: need lighting info asap
Results 1 to 6 of 6
  1. #1 need lighting info asap
    Donating Users onetyme77's Avatar
    texas
    i searched the other threads and could not find one that would help me. I need to know how to change my fog light bulbs on a 98 gp gt. plus i have some halo projector headlight, the kind with the 3 l.e.d's in the inside corner. Does any one know if you can replace the led in the halo, mine is out
  2. #2 Re: need lighting info asap
    West Side Michigan
    To get to the fog lights, you can access the driver side by removing the driver side headlight and looking down. You'll see two bolts where the fog light housing mounts. Remove those and you can slide the housing out and replace the bulb.
    The passenger side you have to go from the bottom up since the horn is in between the headlight and the bolts.
    I think you can replace the LED in the halo.. I lost contact with the place I got them from. One LED in the halo is out in mine too /:
  3. #3 Re: need lighting info asap
    Largo, Florida, United States
    Quote Originally Posted by nawarkk View Post
    You got yours from Dazh Z Racing
    They will Replace your Headlights if they arent working as intended
  4. #4 Re: need lighting info asap
    texas
    no i got my from a ebay company called gforce usa, i called them today and fortunately they are still under warranty and they are going to replace them
  5. #5 Re: need lighting info asap
    texas
    Thanks I gues ill wait till i get my new headlights since i got take one out, i thought you could get to them from the bottom, thanks tho
  6. #6 Re: need lighting info asap
    Nov 2009
    Grand haven
    Good to know ^^^^
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  3. where to buy aftermarket lighting
    By jersey jok3r in forum Visual/Body Modifications
    Last Post: 03-15-2010, 02:13 PM
  4. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
  5. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
