Quote Originally Posted by nawarkk View Post
To get to the fog lights, you can access the driver side by removing the driver side headlight and looking down. You'll see two bolts where the fog light housing mounts. Remove those and you can slide the housing out and replace the bulb.
The passenger side you have to go from the bottom up since the horn is in between the headlight and the bolts.
I think you can replace the LED in the halo.. I lost contact with the place I got them from. One LED in the halo is out in mine too /:
Thanks I gues ill wait till i get my new headlights since i got take one out, i thought you could get to them from the bottom, thanks tho
