Thread: New headlight output HORRIBLE need help (pics)!
Results 21 to 40 of 53
  1. #1 Re: New headlight output HORRIBLE need help (pics)!
    Quote Originally Posted by Frank217 View Post
    Ok I will get a light output ASAP.
    your gunna have to wait till its dark out tho
  2. #2 Re: New headlight output HORRIBLE need help (pics)!
    Norristown, PA
    There not projectors, the light output does suck.
  3. #3 Re: New headlight output HORRIBLE need help (pics)!
    south florida
    No i mean the ACTUAL projector so I can retrofit it inside the housing.
  4. #4 Re: New headlight output HORRIBLE need help (pics)!
  5. #5 Re: New headlight output HORRIBLE need help (pics)!
    Dec 2008
    Lawndale, CA
    I have a set of black headlights like the one's you have. The light output is limited by the black on the housing. As stated the number of reflective mirrors does not matter. What I did notice is that I did a set of black headlights for my brother. He has a stock set that was painted with gloss black and the light reflects better with the gloss black than the flat black one's from ebay.
    Something to think about.
  6. #6 Re: New headlight output HORRIBLE need help (pics)!
    Troy OH
    man, i'm glad you posted this. i'd also like to see the light output on the ground if that's possible.
    and maybe one of them on the car, just to see how they look lol. sorry they turned out like sh!t
  7. #7 Re: New headlight output HORRIBLE need help (pics)!
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Yes, the light output on the black housing's are terrible. The black inside the housing is eating up the light rather than reflecting it. You can either
    a/ throw in hids (this will be better but not great) or
    b/ retrofit projectors- this is the best solution. The morimoto mini's can be purchased from here Bi-xenon: Morimoto Mini - HID Projectors from The Retrofit Source LLC
    The light output with these are incredible. You will never need to use your highbeams again. It's a very easy mod. Hope this helps
    [IMG][/IMG]
  8. #8 Re: New headlight output HORRIBLE need help (pics)!
    south florida
    But after getting the projectors what else would I do? I couln't use the 9007 bulbs single xenons which I have, I would need new wiring too?? any suggestions?
  9. #9 Re: New headlight output HORRIBLE need help (pics)!
    Feb 2009
    canada
    For the projectors I posted you would use a H1 bulb.
  10. #10 Re: New headlight output HORRIBLE need help (pics)!
    You will need D2S bulbs and the D2S socket attachment...ddmtuning has it.
    I think you need to do some homework about projectors and retrofitting, especially if you don't know what kind of bulb goes in a projector
  11. #11 Re: New headlight output HORRIBLE need help (pics)!
    As my experience with any after market headlight I have ever come across. The reflector in the housing is never as good as the OEM one.
    Pure suggestion to the OP, open both sets of headlights and swap the reflectors, its not hard to do.
    And the black housing does not "eat up the light"...whatever that means
  12. #12 Re: New headlight output HORRIBLE need help (pics)!
    Feb 2009
    canada
    Quote Originally Posted by DrunkietheBear View Post
    Wrong. Black absorbs light, meaning it does not reflect light. You have to know this is fact. Sorry you didn't understand my terminology.
  13. #13 Re: New headlight output HORRIBLE need help (pics)!
    SE Level Member NashGT02's Avatar
    Davenport, IA
    glad you posted about this I was gonna buy some. For those of you saying the light output of a GP is bad honestly I dont think its bad at all. I get more than enough lighting out of my factory ones and I have installed Silverstar Ultra headlights and fogs and im happy with em. On a side note would painting the factory headlights black on the housing get the same results? I would expect to lose some lighting as it wont be chrome but im jw.
  14. #14 Re: New headlight output HORRIBLE need help (pics)!
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by NashGT02 View Post
    See my post above.
  15. #15 Re: New headlight output HORRIBLE need help (pics)!
    Troy OH
    i painted the inside of mine the same time i got HIDs. the output was still 8 billion times better. granted my HIDs are high beams, but that combined with the brights and foglight mod i probably look like the sun coming down the road.
  16. #16 Re: New headlight output HORRIBLE need help (pics)!
    No you shouldn't really loose any. Its the reflector from the after market vs OEM that is causing the issue.
    If you really wanted better output with the lights do a relay harness and run some slightly higher wattage bulbs.
  17. #17 Re: New headlight output HORRIBLE need help (pics)!
    south florida
    I understand the black housing MUST take off some output or why would the OEM's be chrome? But anyways the reflectors must have something to do with it, there is no way that 8 chunky reflectors equals like 100 evenly spaced OEM reflectors...But what gets me angry is that the picture of the seller shows it with the OEM reflectors! I emailed them and I'm awaiting a response. I will be posting up output pictures tonight.
  18. #18 Re: New headlight output HORRIBLE need help (pics)!
    even though the amount of reflectors are different, look at the size, the bigger ones make up the amount of smaller ones so in theory it would even itself out. Black housing headlights suck IMO unless they are projector headlight housings. I tried a set of black housing on my GP and the light output was ok but I liked my stock housings better so I gave the black housings back to my friend.
    Snorlax strikes again.
  19. #19 Re: New headlight output HORRIBLE need help (pics)!
    south florida
    Quote Originally Posted by ramairgt2 View Post
    the reflectors are aimed and cut for specific reasons dont ya think? One long mirror would give different output rather than 100 cut up sections of that same mirror
  20. #20 Re: New headlight output HORRIBLE need help (pics)!
    south florida
    Not doing the retrofit anymore, just want to get the output somewhat decent!
  1. Car getting horrible MPG
    By Mercenary in forum General Tech Discussion
    Last Post: 02-02-2011, 10:42 PM
  2. Headlight Question w/ PICS
    By Frank217 in forum Visual/Body Modifications
    Last Post: 06-10-2010, 05:17 PM
  3. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  4. polished aluminum is a horrible disease
    By turbocharged406sbc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2008, 11:11 AM
  5. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
