Thread: Help wiring up my Blazertechs??
Results 1 to 6 of 6
  1. #1 Help wiring up my Blazertechs??
    dfw, tx
    I'm gonna preface this by saying I hate trying to wire up anything...LOL
    But I'd really like to get these lights working again.
    For years and years I had Blazer 3200's on my car and ran the stock wiring, just used the stock bulb, cut the bulb part off, then crimped some wires onto them and ran them to the new bulbs. It worked fine forever til finally one of the plugs burned up somehow...
    Anyways, I've tried twice now to re-wire the foglights back up using a relay and using the info on BackNBlack's website. Never ended up getting them to work.
    So basically I'm hoping someone can walk me through how to get these wired up to work so I can still use the factory fog light switch and turn these babies on.
    So working from the factory fog light wiring harness (the purple and black wires that run down behind the passenger side headlight), where to I need to run wires and such? And what's a good ground point?
    Any help is greatly appreciated...
    Thanks,
    --Marcus
  2. #2 Re: Help wiring up my Blazertechs??
    Joliet, IL
    cut those connectors off and crimp the wires together...done
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: Help wiring up my Blazertechs??
    dfw, tx
    Quote Originally Posted by BoostJunki3 View Post
    The stock harness is all gone out of the car, except the purple and black wire coming down from the main harness. Those connectors are long gone.
    Can I just take the purple wire and run it to the positive side of the fog light, and then take the black and run it to the negative side of the fog light? Or do I need to wire up a relay and all that jazz?
    Right now I've got everything hooked up exactly like the diagram on Back N Black has on his website and they still aren't coming on.
  4. #4 Re: Help wiring up my Blazertechs??
    West Side Michigan
    Do what you just said, Purple is positive and black is negative. You should be fine.
  5. #5 Re: Help wiring up my Blazertechs??
    dfw, tx
    Quote Originally Posted by nawarkk View Post
    So don't worry about wiring it up with a relay harness?
  6. #6 Re: Help wiring up my Blazertechs??
    West Side Michigan
    Nope, don't worry about a relay harness. I've been running H3 55w fog light bulbs for the longest time now. They've been more then fine.
  1. wiring help.
    By chunky in forum Audio, Security & Visual Electronics
    Last Post: 11-22-2009, 03:09 PM
  2. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  3. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  4. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
