Thread: 2004+ Headlight Bounce Kit?
Results 1 to 20 of 46
  1. #1 Re: 2004+ Headlight Bounce Kit?
    its not a dealer sold item. we are just putting weather stripping around the headlights to keep them stable.
  2. #2 Re: 2004+ Headlight Bounce Kit?
    Trenton, Ohio
    I have heard of others saying to use weather stripping too. What kind and how are you keeping it in place?
  3. #3 Re: 2004+ Headlight Bounce Kit?
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Quote Originally Posted by MrsGt2u View Post
    Weather stripping has a sticky backing so that it will stick where you put it
    You could maybe add a little glue or electrical tape if you are worried about it
  4. #4 Re: 2004+ Headlight Bounce Kit?
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    This bouncing kit is a dealer part, just you have to tell them to look up the technical bulletin for the vehicle. BUT.....this kit is for 2004+ GPs I don't think it works on the earlier models.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  5. #5 Re: 2004+ Headlight Bounce Kit?
    SE Level Member Doc Banger's Avatar
    GTA, Ontario, CA
    I have the metal brackets installed in my '04 GP - been like that since I bought the car - but they don't have the retainer bolts in the top, and there aren't any holes tapped where they would mount. The metal brackets snap into place but every once in a while I hit a good bump or someone drops the hood down good and hard and they pop loose. No big deal, I just check them whenever I gas up and check the oil, but can I assume I only have half the fix kit installed?
    2004 Grand Prix GT
    3.8L V6
    Pretty much stock
  6. #6 Re: 2004+ Headlight Bounce Kit?
    Nov 2009
    From what you are saying. Yeah, i'd say you only have part of the fix kit installed. Did you check the outside edge of the frame to see if the 90 Degree Metal Bracket was installed? All things considered, you could probably drill, tap and screw down a just about any sized bolt into the frame of the vehicle to finish the kit.
  1. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 3
    By dsh1106 in forum How To Write-Ups/Tech Tips
    Last Post: 02-09-2013, 06:55 PM
  2. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 2
    Last Post: 04-17-2009, 02:20 PM
  3. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 1
    Last Post: 04-17-2009, 02:17 PM
  4. Valve Float and Bounce
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-19-2008, 04:02 PM
