Thread: 2004+ Headlight Bounce Kit?
Results 21 to 40 of 46
  1. #21 Re: 2004+ Headlight Bounce Kit?
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    This bouncing kit is a dealer part, just you have to tell them to look up the technical bulletin for the vehicle. BUT.....this kit is for 2004+ GPs I don't think it works on the earlier models.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #22 Re: 2004+ Headlight Bounce Kit?
    SE Level Member Doc Banger's Avatar
    GTA, Ontario, CA
    I have the metal brackets installed in my '04 GP - been like that since I bought the car - but they don't have the retainer bolts in the top, and there aren't any holes tapped where they would mount. The metal brackets snap into place but every once in a while I hit a good bump or someone drops the hood down good and hard and they pop loose. No big deal, I just check them whenever I gas up and check the oil, but can I assume I only have half the fix kit installed?
    2004 Grand Prix GT
    3.8L V6
    Pretty much stock
  3. #23 Re: 2004+ Headlight Bounce Kit?
    Nov 2009
    From what you are saying. Yeah, i'd say you only have part of the fix kit installed. Did you check the outside edge of the frame to see if the 90 Degree Metal Bracket was installed? All things considered, you could probably drill, tap and screw down a just about any sized bolt into the frame of the vehicle to finish the kit.
  4. #24 Re: 2004+ Headlight Bounce Kit?
    GT Level Member jmoore4294's Avatar
    What good does that 90 degree bracket do? Keep the header panel from vibrating? I put in the new metal "L" brackets and while it didn't stop ALL vibration, it made a heck of a difference.
  5. #25 Re: 2004+ Headlight Bounce Kit?
    Nov 2009
    Yeah, i think the point is to make that part of the plastic frame more rigid to help cut down on vibrations.
  6. #26 Re: 2004+ Headlight Bounce Kit?
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Just finally fixed mine by looking at another thread. The best solution I have found is get some Styrofoam about say 2 inches thick and about 4 to 6 inches long and stick the piece between the metal on the bumper and the bumper cover just below the headlights. You may need to slightly bend the mounting on the frame of the car where the lights attach to but that will definitely fix any problem with bouncing. You can even use a piece of wood to do it also like say a 2 by 4 but I wouldn't recommend that because of it getting wet
  7. #27 Re: 2004+ Headlight Bounce Kit?
    Nov 2009
    The kit is pretty inexpensive and works pretty well. But maybe for a 2003 or earlier that's the best you can do. I got a 2004 so the kit for my car worked awesome.
  8. #28 Re: 2004+ Headlight Bounce Kit?
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    My headlights bounce pretty bad on my 01. I can wiggle them both up and down quite a bit, almost like they arent fully bolted into the header panel (do these cars even have a header panel?) I will have to take a pic and have someone here look, because upon further inspection, the lights dont seem to be correct for my car at all. The inside of them both, towards the center grill, there is a very noticeable gap that I feel shouldnt be there. I have HIDs with projectors and a pair of halos on each side. Ill take a pic when its light out and post it here, maybe someone cal tell me what the heck somebody did to these. If the lights are in fact wrong, and I can get new housings that fit correctly and swap the projectors and halos over, I might do that.
    2001 Grand Prix GTP, silver w/ black hood, silver bullit 17s
  9. #29 Re: 2004+ Headlight Bounce Kit?
    Midwest USA
    So I've got an '04 and my lights seem to bounce pretty bad. From what I gather here, there is a tech bulletin on this? If so, will the dealer install them free? The kit itself looks to be about $11, but the stupid shipping on GMDirect is $12. I hate when that happens...
  10. #30 Re: 2004+ Headlight Bounce Kit?
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Has anyone found a recent write-up with pics? Ive had the kit sitting in the garage for a year now and dont have a clue on how to install it.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  11. #31 Re: 2004+ Headlight Bounce Kit?
    Quote Originally Posted by sdavis11b View Post
    Don't over think it. You don't have to do everything that the install instructions state. Just use the metal brackets in place of the plastic flimsy ones and you won't have any bounce anymore and if you like you can drill the holes for the supplied bolts to hold the metal tabs down.
    04 Comp G.
  12. #32 Re: 2004+ Headlight Bounce Kit?
    Atlanta, GA
    Thats exactly what i have done so far and the bounce is still very bad. Especially with my HIDs. Makes me feel like im driving a cheap beat up honda with duct taped headlights. I would think i could make due with detailed written instructions. Any help would be appreciated.
  13. #33 Re: 2004+ Headlight Bounce Kit?
    Let me see if I can find the instructions for you and that's shocking you still have bounce it eliminated mine just by using the brackets.
    04 Comp G.
  14. #34 Re: 2004+ Headlight Bounce Kit?
    Atlanta, GA
    Thanks!
  15. #35 Re: 2004+ Headlight Bounce Kit?
    Atlanta, GA
    Anyone? Would the dealership have instructions for it that they would be willing to give me?
  16. #36 Re: 2004+ Headlight Bounce Kit?
    Atlanta, GA
    Could someone atleast take pics of the brackets and where they are so I can get a general idea?
  17. #37 Re: 2004+ Headlight Bounce Kit?
    Nov 2012
    Madison
    Kind of crappy TSB pics
    Looking for more information re TSBs
  18. #38 Re: 2004+ Headlight Bounce Kit?
    Atlanta, GA
    Thank you so much, thats absolutley what i was looking for!
  19. #39 Re: 2004+ Headlight Bounce Kit?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I fixed my bounce with some black pucky lol
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  20. #40 Re: 2004+ Headlight Bounce Kit?
    Nov 2009
    search on this webside, someone typed up instructions for it a while ago. I'll try to find it and repost the link.
    Edit: The instructions/write up to install them have been taken down. I don't believe that I saved a copy at all, sorry man.
  1. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 3
    By dsh1106 in forum How To Write-Ups/Tech Tips
    Last Post: 02-09-2013, 06:55 PM
  2. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 2
    Last Post: 04-17-2009, 02:20 PM
  3. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 1
    Last Post: 04-17-2009, 02:17 PM
  4. Valve Float and Bounce
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-19-2008, 04:02 PM
