Thread: headlights not fitting flush
Results 1 to 8 of 8
  1. #1 headlights not fitting flush
    Aug 2008
    Long Island, New York
    my friend just bought a new gtp, and both headlights dont sit flush with the center part (the part with the pontiac logo), they stick out a little. im pretty sure it has new capsules because they are gray, and they should be black so that could have something to do with it. is there any way to adjust this?
  2. #2 Re: headlights not fitting flush
    Kansas
    I cant tell you your problem but mine are gray too and they fit perfect. They were replacements when i first got the car.
    SOLD 1999 GT Silvermist TS
  3. #3 Re: headlights not fitting flush
    Nov 2008
    Cedar Rapids, IA
    Do they bounce? Can you move the headlights around with your hand? Maybe the tab in the back isn't seated correctly. That could cause them to stick out.
    2002 GTP Coupe *Bronzemist *FWI *180t *2.5 ZZP o/r pipe *Poly mounts *GMPP rear sway *GMPP trailing arms *Tune by FoSHO99
  4. #4 Re: headlights not fitting flush
    Joliet, IL
    there isnt a horizontal adjustment on the stockers is there......i know they had vertical just cant remember.....should got projectors and tinted the corners like me to complete your murdered out look
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  5. #5 Re: headlights not fitting flush
    Aug 2008
    Quote Originally Posted by BoostJunki3 View Post
    oh this isnt for me, its for my friends car i have tinted stockers that fit just fine. and believe me mine is blacked out! its like the batmobile...
    they do bounce a little bit, and we couldnt seem to get the rear mounting tab to slip in i dont think. but i still dont think it would cause it to stick out that much...
  6. #6 Re: headlights not fitting flush
    Nov 2008
    Cedar Rapids, IA
    That mounting tab is what holds the light secure and in place. If it isn't in all the way or at all then it is entirely possible that your lights won't sit flush.
  7. #7 Re: headlights not fitting flush
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    There's both horizontal and vertical adjustment. There are two E-8 (IIRC) Torx screws (6-point star shaped) on top of the headlight.
    This is how mine were shipped to me. You can see how the horizontal alignment is maxed out in this picture. That will result in the huge gaps you describe.
    Any time you get new headlights, you want to aim them. You can attempt it yourself (it's a lot easier on projectors because of the sharp cutoff), but it's probably better to take it to a shop.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  8. #8 Re: headlights not fitting flush
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    mine is like this too but my problem is the actual fiberglass assembly behind the lights is bowed...havent tried fixing it yet as i have too much other stuff to do but i think there is a way to adjust this so it sits better
  1. Transmission Mount Fitting
    By PGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2009, 03:46 PM
  2. FPR vac fitting
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:50 PM
  3. Transmissions fitting
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 09:00 PM
  4. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
