Thread: HID Help Needed Please.
Results 1 to 20 of 21
  1. #1 Re: HID Help Needed Please.
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by Subzero121800 View Post
    That thread helped a little bit. I'm not willing to get rid of the Auto on feature and off feature of the headlights though. Kind of like that since i am lazy and always forget to turn them back off when i get to the construction areas in the daytime and have to turn my headlights on and then forget about them.
    I have an '07 GP so I can't really speak for the 97-03 for fact, but I think if you pull that wiring harness off of that heatsink in the dash it disables the DRL's but keeps auto function intact. Anyone with a 97-03 on here that did this?
  2. #2 Re: HID Help Needed Please.
    Scottdale, PA
    still wondering about the relay part or even if i have to do it. And why my side marker and orange light are out for a reason like would the side marker being out make them both out when the driver side are both on when car started and lights full on. ?
  3. #3 Re: HID Help Needed Please.
    Indiana
    You don't HAVE to do the relay harness, but it will keep your ballasts and bulbs from failing prematurely and would solve any flickering/not lighting problems.
    The sidemarker being out would cause your halo not to work properly since the sidemarker bulb is completing the circuit. I still say you should connect the halo's + to the brown (parking lamp) wire and the halo's [-] to the car's ground, it would solve that problem.
  4. #4 Re: HID Help Needed Please.
    Scottdale, PA
    the halo's work fine. The lights out are the Passenger side Side Marker and Orange turn signal. The turn signal only comes on when the turn signal is activated.
  1. Opinion Needed....
    By Bgerk in forum Tires & Wheels
    Last Post: 07-13-2009, 01:58 PM
  2. help needed imediatly!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 12:51 AM
