Thread: HID Help Needed Please.
Results 1 to 20 of 21
  1. #1 Re: HID Help Needed Please.
    Scottdale, PA
    Quote Originally Posted by RedDawnGXP View Post
    Nice projectors. Quick question though, for the 97-03 Grand Prix are the DRL's the highbeam or the lowbeam? Did you disable them?
    The DRL is the Low which is the HID And i do not know how to disable them. If i take off the DRL would that also disable my lights turning on and off automatically ?
  2. #2 Re: HID Help Needed Please.
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by Subzero121800 View Post
    DRL's operate at a lower voltage than the normal headlights. I think for the 97-03's you have to unplug a wire harness from a load resistor. It's behind the panel on the driver's side dash. I think someone did a write up on that. I'll try to find it.
  3. #3 Re: HID Help Needed Please.
    Indiana
  4. #4 Re: HID Help Needed Please.
    Scottdale, PA
    That thread helped a little bit. I'm not willing to get rid of the Auto on feature and off feature of the headlights though. Kind of like that since i am lazy and always forget to turn them back off when i get to the construction areas in the daytime and have to turn my headlights on and then forget about them.
  5. #5 Re: HID Help Needed Please.
    Indiana
    I have an '07 GP so I can't really speak for the 97-03 for fact, but I think if you pull that wiring harness off of that heatsink in the dash it disables the DRL's but keeps auto function intact. Anyone with a 97-03 on here that did this?
  6. #6 Re: HID Help Needed Please.
    Scottdale, PA
    still wondering about the relay part or even if i have to do it. And why my side marker and orange light are out for a reason like would the side marker being out make them both out when the driver side are both on when car started and lights full on. ?
  7. #7 Re: HID Help Needed Please.
    Indiana
    You don't HAVE to do the relay harness, but it will keep your ballasts and bulbs from failing prematurely and would solve any flickering/not lighting problems.
    The sidemarker being out would cause your halo not to work properly since the sidemarker bulb is completing the circuit. I still say you should connect the halo's + to the brown (parking lamp) wire and the halo's [-] to the car's ground, it would solve that problem.
  1. Opinion Needed....
    By Bgerk in forum Tires & Wheels
    Last Post: 07-13-2009, 01:58 PM
  2. help needed imediatly!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 12:51 AM
