Thread: need help with tail lights
Results 1 to 13 of 13
  1. #1 need help with tail lights
    Aug 2008
    Pennsylvania
    how do i take the tail lights apart i mean is there a way to take the clear part away from the back black part? i have a 98 grand prix
  2. #2 Re: need help with tail lights
    you have to cut them apart and then epoxy them back together if you want to do that. ive done it. it is a lot of work.
    but you cannot take the black 'stripes' off the tail light. you can only break the reflectors out of it so they are cleared instead of being red.
  3. #3 Re: need help with tail lights
    Aug 2008
    Pennsylvania
    okay thanks
  4. #4 Re: need help with tail lights
    GTP Level Member dstout's Avatar
    ky
    I know people bake the stock headlights in the oven at around 200* for a few minutes to take them apart but I'm not sure if you can bake the tails to get them apart...I can search for the link on headlight baking if you are interested and want to try that
  5. #5 Re: need help with tail lights
  6. #6 Re: need help with tail lights
    ky
    cant bake the tails.
    Hmmmm......I guess that won't work then.
  7. #7 Re: need help with tail lights
    ky
    How did you get them apart?
    Did you use a Dremel?
    I have never removed mine but it can't be that hard. I'm sure just a few screws to remove.
  8. #8 Re: need help with tail lights
    yeah, i just used a small dremel bit. i then had to epoxy them back together once i got all of the reflector out. there is a certain area you want to cut out, there is actually a really good thread on clubgp that i followed. id search there. the clear tails were cool, but i like them tinted more.
    you take them off the car with a few butterfly nuts from the trunk. move the trunk liner and youll see what im talking about.
  9. #9 Re: need help with tail lights
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I attemped a few ways to do this with a spare tail I had and it is difficult. I agree the only way is to cut it apart. I saw another thread where someone broke the reflective part up with a screwdriver and hammer.
  10. #10 Re: need help with tail lights
    SE Level Member Leon's Avatar
    Apr 2009
    US
    Anyone know how to remove tail light water? lol
  11. #11 Re: need help with tail lights
    SE Level Member TheDesertFox's Avatar
    Feb 2009
    Orrtanna
    Quote Originally Posted by Leon View Post
    Hair dryer
  12. #12 Re: need help with tail lights
    GT Level Member Preotic's Avatar
    Missoula, MT
    If you want to run cleared tails without tinting them, then you'll need to cut open the back. If you want to clear them and then tint them you can use the hammer, screwdriver and dykes. The hammer, screwdriver and dykes method leaves a little red lens left that you can't get to, but you can't notice it once it is tinted. Also when doing the hammer, screwdriver and dykes method don't attempt to remove the white lens for the backup light, it is too thick to break and even thicker you can't cut it with dykes.
    Her is a pic of some tails i cleared with hammer and had lightly tinted.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  13. #13 Re: need help with tail lights
    quebec, canada
    those look hot
  1. Painting Tail Lights
    By thegoldenboy in forum Visual/Body Modifications
    Last Post: 06-19-2008, 11:05 AM
  2. Tail Lights
    By heat in forum Visual/Body Modifications
    Last Post: 05-06-2008, 06:00 PM
  3. tail lights
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 01:58 PM
  4. tinting tail lights???
    By kingd44 in forum Visual/Body Modifications
    Last Post: 04-09-2008, 03:19 PM
