Thread: Rear bumper removal - 2004 GTP.
Results 1 to 14 of 14
  1. #1 Re: Rear bumper removal - 2004 GTP.
    Saraland Alabama
    you want it on the car when painted, unless you like it not matching
  2. #2 Re: Rear bumper removal - 2004 GTP.
    Banned
    NW Corner of CT.
    Quote Originally Posted by archemedes View Post
    Correct me if I'm wrong but Black is the easiest color to paint.....there should be NO blending need what so ever.....(But I personally wouldn't use a rattle can unless it's a temp fix.....JMO
  3. #3 Re: Rear bumper removal - 2004 GTP.
    Saraland Alabama
    Quote Originally Posted by RKELC View Post
    depends on the black, there are different shades, and what not (yes it is the easiest to match though)
  4. #4 Re: Rear bumper removal - 2004 GTP.
    Saraland Alabama
    Quote Originally Posted by Flip View Post
    All right....GM as ONE black for Grand Prixs .... 8555 paint code.. If you dont remove the bumper to paint it then why waste your money to paint it in the first place.Why do you want paint lines & maybe peeling clear down the road..Remove the bumper it the only way to do it RIGHT. If a bodyshop cant match this black then they have a problem..I would start with the painter.. If it was a Lambo or Bentley I may see what you are saying...7 different blacks on the same year cars.. But it a GM !!!... Sorry for being honest.
    But it has to be mixed, and then the humidity changes color (I ran a body shop and went to school for body work) if you get a line from the paint on a bumper it was applied too heavy. Peeling clear is from bad prep, or incompatible products used (I did the recalls for GM and Chrysler on peeling clear coats) yes it should match, but I have seen it not match, and the bumper being so flexible it will crack while putting it back on (I loosen the bolts if the gaps are real tight)
  5. #5 Re: Rear bumper removal - 2004 GTP.
    Easy as in color match - hard as in gloss, smooth, no orange peel, no "scratches" etc.
  6. #6 BCM
    Nov 2008
    Mexico
    Somebody knows if its possible reprogram the Body Control Module.
    Because I bougth a used BCM but I try to put into the car, and this does not power on, it appears on Stereo "locked".
    Do I need to buy a new BCM??
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
  3. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
  4. 2004+ wiring diagrams
    By Toasty in forum General Tech Discussion
    Last Post: 01-14-2008, 01:15 PM
  5. Rear door will not shut *Solved*
    By Fish in forum Visual/Body Modifications
    Last Post: 12-25-2007, 02:53 AM
