Thread: HID recommendations
Results 41 to 60 of 78
  1. #41 Re: HID recommendations
    Apr 2011
    North Los Angeles
    Quote Originally Posted by coolone View Post
    Late to the game here, my apologies... But here's my $.02
    Hid's from the Retrofit Source are second to none, they produce a quality product and back it up (warranty). I have an HID kit from them I placed into NEW stock housings. Yes it can be done, two things are relevant, one is the filament on the HID lamp is positioned differently into the housing and if you measure the stock placement and subsequently mimic that with the HID's, the light thrown from the housing will be just the same, but more intense. Now, we all know the stock housings sux, so that is why many opt for the projectors as the projectors will put more light on the road where you need it.
    Anyways, there was a write up on fixing the placement of the hid lamps correctly into the housing with stock headlights, search... If you can't find it let me know, I think I have some screen captures of it. And even then, I have my stock lights aimed a little lower than usual and I never get flashed... But they are bright, lol
    that said... $280 is a steal, something I may consider for my GTP ; )
    I dont disagree with you but if theres a 50$ option that is comparable i may go with that. Whats your opinion on the difference between the cheap vs more expensive hids mentioned here
  2. #42 Re: HID recommendations
    Antioch, IL
    Quote Originally Posted by steelholder View Post
    Can you briefly explain what steps took you 30 min?
    Pop hood, take out headlights, run harness, attach, reinstall, close hood.
    2009 Challenger SRT8
    Expert at being gay.
  3. #43 Re: HID recommendations
    Nov 2012
    Madison
    TRS=quality and a more useful warranty
  4. #44 Re: HID recommendations
    Oct 2013
    michigan
    just had my second ddm tuning bulb die, less than a year old. had a new set of tyc head lamps waiting for an pnp led bulb to show up, installed those thursday. similar light output as the pnp hids in factory housings. unsure if related but i had new tyc housings last year when I installed the hids, housings were severely faded and starting to yellow. hids were 55w.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  5. #45 Re: HID recommendations
    Apr 2011
    North Los Angeles
    Quote Originally Posted by jlbayes View Post
    Dumb question but was anything covered by warranty ddm wise?
  6. #46 Re: HID recommendations
    Oct 2013
    michigan
    i haven't tried yet. had to have the car to drive so i just pulled it all.
  7. #47 Re: HID recommendations
    Nov 2012
    Madison
    Do some searches on DDM warranty problems.
    If TRS ballasts poop.....you cut the cord and email the pic.....they send a new one......too easy.
    Hell get a DDM set for fifty....I did...they made it a year....then bugged out
  8. #48 Re: HID recommendations
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Ran ddm in my Impala for 6 years, never an issue and put 100k on the car before I sold it 215k, btw where are you guys seeing 150$ for full retrofit from TRS. Cheapest I see is 270$! 99GTP!
  9. #49 Re: HID recommendations
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Jnibbs24 View Post
    .....btw where are you guys seeing 150$ for full retrofit from TRS. Cheapest I see is 270$!
    $150 is on the cheap side. They often have projectors in their clearance section for well under $100. If you buy brand new, they are $110-140+. Then you need bulbs, which are another $40+. Most people doing retrofits already have PNP kits installed, so no need to buy ballasts and wiring harness. If you need these components, you are now in the $270 range that you noted.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #50 Re: HID recommendations
    Nov 2011
    NY
    I believe you get what you pay for... The $60-$80 units are ok, they work, can't say they don't. I Have the Retrofit Source units and like I said are second to none, 4 years now and not a hitch! So they already paid for themselves as I feel even if they burnt up tomorrow, I got my $ out of em. I had cheap units on other cars before and never really lasted like the Retrofit Source.
  11. #51 Re: HID recommendations
    Apr 2011
    North Los Angeles
    If anyone can post a link for the cheaper ddm or similar priced hid's for an 07 gp id appreciate it.
    Is there a specific harness im looking for?
  12. #52 Re: HID recommendations
    Antioch, IL
    I already gave you the link.................................
  13. #53 Re: HID recommendations
    Apr 2011
    North Los Angeles
    Quote Originally Posted by ItHurtz View Post
    I know nothing of the 04+ cars I have no idea if they are the same or not.
    Install depends if your me or forrest gump, I did my car in 30minutes, womens g6 in 40min, brothers camaro 1hr. Time includes shutting the hood closed and going back inside.
    And we already went through this, thanks though.
  14. #54 Re: HID recommendations
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    What about these? Anyone have experience with them?
    https://www.amazon.com/gp/aw/d/B019E...222--1-1---1-0
  15. #55 Re: HID recommendations
    Enfield, CT
    Just get retrofits
    Sent from my LG G3
  16. #56 Re: HID recommendations
    Topeka, KS
    Quote Originally Posted by HighOctaneRacing View Post
    Just get retrofits
    Sent from my LG G3
    Buy the assymblies off RockAuto for like 30 a side then go to the retrofit source and get some morimoto's.
  17. #57 Re: HID recommendations
    Oct 2016
    Davisburg, MI
    Quote Originally Posted by rynoman03 View Post
    All of the headlight assemblies rockauto sells are knockoffs of what I already have (original equipment). How does that help?
  18. #58 Re: HID recommendations
    Topeka, KS
    Well you wanted those other ****ty HIDs above. How did that help you?
    Sent from my VS990 using Tapatalk
  19. #59 Re: HID recommendations
    Enfield, CT
    X2
    Sent from my LG G3
  20. #60 Re: HID recommendations
    Oct 2016
    Davisburg, MI
    Um, that was my question in the post. Regardless, I'm interested in a better lighting package that will not blind oncoming drivers.
  1. New Tire Recommendations (GTP)
    By kamposs in forum Tires & Wheels
    Last Post: 02-25-2015, 09:27 AM
  2. Recommendations on a tune.
    By Slopar00 in forum Introductions/Noob Questions
    Last Post: 09-19-2014, 08:29 PM
  3. Oil recommendations
    By Pitviper in forum Turbo
    Last Post: 09-16-2014, 05:20 PM
  4. Amp recommendations
    By Montana in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2013, 05:40 AM
  5. Looking for decent 5.25s, want your recommendations
    By 98L36 in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2011, 10:50 AM
