I dont disagree with you but if theres a 50$ option that is comparable i may go with that. Whats your opinion on the difference between the cheap vs more expensive hids mentioned here
just had my second ddm tuning bulb die, less than a year old. had a new set of tyc head lamps waiting for an pnp led bulb to show up, installed those thursday. similar light output as the pnp hids in factory housings. unsure if related but i had new tyc housings last year when I installed the hids, housings were severely faded and starting to yellow. hids were 55w.
i haven't tried yet. had to have the car to drive so i just pulled it all.
Do some searches on DDM warranty problems.
If TRS ballasts poop.....you cut the cord and email the pic.....they send a new one......too easy.
Hell get a DDM set for fifty....I did...they made it a year....then bugged out
Ran ddm in my Impala for 6 years, never an issue and put 100k on the car before I sold it 215k, btw where are you guys seeing 150$ for full retrofit from TRS. Cheapest I see is 270$! 99GTP!
$150 is on the cheap side. They often have projectors in their clearance section for well under $100. If you buy brand new, they are $110-140+. Then you need bulbs, which are another $40+. Most people doing retrofits already have PNP kits installed, so no need to buy ballasts and wiring harness. If you need these components, you are now in the $270 range that you noted.
I believe you get what you pay for... The $60-$80 units are ok, they work, can't say they don't. I Have the Retrofit Source units and like I said are second to none, 4 years now and not a hitch! So they already paid for themselves as I feel even if they burnt up tomorrow, I got my $ out of em. I had cheap units on other cars before and never really lasted like the Retrofit Source.
If anyone can post a link for the cheaper ddm or similar priced hid's for an 07 gp id appreciate it.
Is there a specific harness im looking for?
I already gave you the link.................................
What about these? Anyone have experience with them?
https://www.amazon.com/gp/aw/d/B019E...222--1-1---1-0
Just get retrofits
Sent from my LG G3
Buy the assymblies off RockAuto for like 30 a side then go to the retrofit source and get some morimoto's.
Well you wanted those other ****ty HIDs above. How did that help you?
Sent from my VS990 using Tapatalk
Um, that was my question in the post. Regardless, I'm interested in a better lighting package that will not blind oncoming drivers.
