Thread: possible turbo build
Results 1 to 20 of 32
  1. #1 possible turbo build
    Kemmerer, Wyoming
    I have a friend who has some mad fabrication skills, and we discussed putting together a turbo setup. he said he would start with 2 front oem manifolds, and modify one of them to use on the rear. he also said if I left my car at his place for a couple weeks he would do the whole install, to make sure the fit and finish was good. we are planning on doing a T3 61MM turbo. the site I am looking at ordering from is www.on3performance.com, and the guy doing the fab work and installation will vouch for them. so far all the parts I have in my shopping car total about 750, and include the turbo, wastegate, blow off valve and turbo blanket.
    my current setup is an xp cam with ported heads, 90 lb ls6 springs, and a phenolic air to water intercooler. I'm planning on keeping the air to water intercooler, but I will open up a supercharger case for more airflow.
    I am planning on installing 130 lb valve springs, and a double roller timing chain. one thing I am wondering is that since I am already going to have the harmonic balancer off, and am going to a turbo setup, is there a good naturally aspirated harmonic balancer that I could use?
    http://www.on3performance.com/
  2. #2 Re: possible turbo build
    May 2012
    Where winter never ends
    Get ready to build that trans up
    2000 Regal - Winter Beater
  3. #3 Re: possible turbo build
    Apr 2015
    Columbus, OH
    Yesterday it was drilled rotors, today turbo....tomorrow you'll be twin charging. Yeah, I'd put that trans at the top of your list for sure.
    Top Swapped 01 Imp
  4. #4 Re: possible turbo build
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Why not go T4. Leaves more room for improvement.
    Also, get a good quality wastegate/s and blow off valve.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  5. #5 Re: possible turbo build
    Kemmerer, Wyoming
    already done the transmission. I have a dynotech, with a dynotech 300m input shaft and a dynotech 7/8's chain. it has been running hotter than normal, so I'm probably going to drop the oil pan and check the fluid and filter. I changed the fluid one time already, but its still getting hotter than normal, so hopefully I didn't burn up some clutches, or whatever is causing the higher temps.
    I have a hard time sticking to one idea, I end up changing my mind more times than I care to admit.
    one thing I was wondering is if the T3 61 mm turbo is going to be a good match for a 3800 with an xp cam.
    edit: question answered: we talked about doing a T4 because it would give more room for more power, but the input shaft I have is probably only good for 375 hp, and I would rather not drop the transmission for a repair. the T3 will be close to maxed out, but will spool up very fast.
  6. #6 Re: possible turbo build
    May 2012
    T4 67 or 70 IMHO. But I like big turbos. Brake boost and they will take you to the moon. And I'm sorry but that wimpy 7/8 is going to stretch like a rubber band with powaaa
    Sent from my VS986 using Tapatalk
  7. #7 Re: possible turbo build
    Kemmerer, Wyoming
    Quote Originally Posted by ADecker View Post
    kind of why I didn't want to make a lot of power
  8. #8 Re: possible turbo build
    May 2012
    Your going to be 350-400 on even low boost. It's going to stretch
  9. #9 Re: possible turbo build
    Yup you'll be doing more work on that trans. If you turbo it.
    04 Comp G.
  10. #10 Re: possible turbo build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SgtMarshal View Post
    hes gonna start with 2 front OEM cast mainfolds??? the most restrictive part of the stock exhaust??? sounds like a quality plan to me...
    your friend isnt GOJO83 is he?!?!
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  11. #11 Re: possible turbo build
    May 2012
    Why not make headers
  12. #12 Re: possible turbo build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    with his buddy's mad fabrication skills that would be the way to go...
  13. #13 Re: possible turbo build
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    I am friends with GOJO83, but he is not the person doing the work. I am aware of the restriction, and thought the heat and pressure would be better to get the turbo spooled up faster.
  14. #14 Re: possible turbo build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    negative ghost rider...let the motor breathe...
    suddenly your inability to stick with one single idea about your car makes more sense...
    EDIT: if you do use a t3 61mm turbo it wont have any issues with spooling...its not exactly a monster
  15. #15 Re: possible turbo build
    Kemmerer, Wyoming
    ...SQUIRREL....
    will porting the exhaust manifold be sufficient?
  16. #16 Re: possible turbo build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    ...SQUIRREL....
    honestly if you dont have a want for more then 400hp i would just run both stock front and rear manifolds. but i certainly wouldnt **** with making a rear out of a stock front mani. thats just counter productive...
    if and when you want more...build/buy tubular manifolds
  17. #17 Re: possible turbo build
    Nov 2011
    NY
    Ok, even bough I'm sure I'll get bashed as dissuading you. That said, I highly suggest you take a step back, do some research and decide in exactly what you want to do, where you want to take your engine/car. It's apparent you really aren't sure and was my point in other posts. You think your Dynotech tranny build is up to the task of a turbo powered 3800? I can assure you if you don't have $3500+++ invested in it, I doubt it. But there are lots of knowledgable people here who've done turbo builds, pick their brains, get lots of info., make a plan, then maybe then, start getting your stuff together. Then contact your buddy about assembly : )
    Good Luck!
  18. #18 Re: possible turbo build
    Kemmerer, Wyoming
    Quote Originally Posted by coolone View Post
    Good Luck!
    I'm not real sure if my dynotech will hold up. Nobody really runs them anymore, but the person I got it from used it on their turbo 3800, I think it was an Impala, but I can't remember for sure. It was Swiggles transmission. the only thing different is that it has a dynotech 300m input shaft and a dynotech 7/8's chain with a zzp 2500 stall converter.
    as far as making a plan, my plan is to do the small turbo build, and then leave it alone. if the transmission goes out, I'll rebuild it as necessary. the car isn't a daily driver anymore, so if it breaks, its not a big deal. I don't want to do some crazy hp build, I just want a little bit more power. If I feel like I want more power, I will buy a 4th gen Camaro or a 5.3 half ton Chevy. I understand the limitations of a front wheel drive car. I think this plan is pretty reasonable.
  19. #19 Re: possible turbo build
    GXP Level Member
    Mar 2015
    Tomball
    Good Luck!
    Mann and I thought my ADD was bad.
    Ok, I totally see your point now. Still think it was a worthwhile discussion.
  20. #20 Re: possible turbo build
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Personally I think a smaller turbo is the way to go. Most of the big power builds I see happen tear themselves apart leading to a partout shortly after. That is if you are not wanting to dump a ton of money into a transmission. I have the same dynotec input shaft along with a 7/8 chain. I am probably running 350-375 whp. So far so good with 45 or so track passes and lots of tearing up the streets. As you said if it breaks I will grab another $75 junkyard trans and swap over hard parts.
    It is plenty fast to be fun and seems to make passes pretty close to a lot of guys running t4, big cam, etc. Not trying to step on any toes but if you like driving and enjoying you car instead of wrenching on it all the time it seems like a good option. Just my 2cents.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  1. help with my turbo build please.....
    By Bino0527 in forum Turbo
    Last Post: 04-23-2013, 11:31 AM
  2. Turbo build. Run and tell that.
    By Wotgtp in forum Turbo
    Last Post: 05-25-2012, 04:08 PM
  3. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  4. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
