Thread: help with launching
Results 1 to 4 of 4
Threaded View
  1. #2 Re: help with launching
    Nov 2012
    Erlanger, KY
    Use a momentary switch, with the IAT sensor deal. So when pushed in, see's no reading. Then use the IAT table to drop you timing down to nothing.
    No timing, car won't be making power, so can build up boost. Then let go of the button when you let off the brake.
    I have my PCM setup to where regular timing tables are setup to drop timing in a certain RPM range and PEvsTime table to richen up the fuel, to kick turbo some in the ass.
    Worked well on my 3000 stall, stock brakes, and small booster.
    I can launch at 10psi now... But the method I use, with no switch, leaves me a small window to launch in.. to low of an RPM.. and it bogs... to high of an RPM, and car lurches forward and
    will just smoke show the tires...
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  1. Launching a gtp help/advice
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 03-16-2011, 10:22 AM
  2. Tranny slipping? Launching probs..
    By 9ordohz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2011, 04:28 AM
  3. Launching tips?
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 10-23-2009, 08:23 PM
