Hey guys. I am just trying to squeeze a few tenths out of the car at the track. It consistantly runs 12.0-12.3. I would like to add a little more timing or boost. I will be tuning with dhp and a wideband after the install. I just ordered the devils own progressive dvc-30 kit. I am going to be starting with the 7gph nozzle that comes with the kit. According to their site it should be close to what I need. If not I will change as needed. I also plan on running a 50/50 mix.
I have a few questions. First, has anyone here run meth using a l36 intake? Any suggestions on nozzle placement. I know t/b spacer is an option but the shape is different between the l36 and l67. It may work but I'm not sure. I am not going to be using multiple nozzles in the lower intake so thats out. I would really like to keep the stock l36 maf. Does drilling and tapping a hole in the neck of the intake close to the t/b sound like a bad idea? Thats kind of what I'm leaning toward but I would like some input.
Not sure if everyone can see my sig. 97 gt with l67 bottom end. Hx35, xp cam, 130#, 42.5.
