Thread: Meth/water injection with l36 intake.
Results 1 to 15 of 15
  1. #1 Meth/water injection with l36 intake.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Hey guys. I am just trying to squeeze a few tenths out of the car at the track. It consistantly runs 12.0-12.3. I would like to add a little more timing or boost. I will be tuning with dhp and a wideband after the install. I just ordered the devils own progressive dvc-30 kit. I am going to be starting with the 7gph nozzle that comes with the kit. According to their site it should be close to what I need. If not I will change as needed. I also plan on running a 50/50 mix.
    I have a few questions. First, has anyone here run meth using a l36 intake? Any suggestions on nozzle placement. I know t/b spacer is an option but the shape is different between the l36 and l67. It may work but I'm not sure. I am not going to be using multiple nozzles in the lower intake so thats out. I would really like to keep the stock l36 maf. Does drilling and tapping a hole in the neck of the intake close to the t/b sound like a bad idea? Thats kind of what I'm leaning toward but I would like some input.
    Not sure if everyone can see my sig. 97 gt with l67 bottom end. Hx35, xp cam, 130#, 42.5.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  2. #2 Re: Meth/water injection with l36 intake.
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    sounds like a great idea if your gonna run a single nozzle. go bigger too.
  3. #3 Re: Meth/water injection with l36 intake.
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I 2ould get a tb spacer plate should be able to find one for a gtp on eBay for cheap. Don't tap the manifold plastic is too thin. Any reason u don't just switch to racegas?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  4. #4 Re: Meth/water injection with l36 intake.
    Daytona, florida
    Quote Originally Posted by NebTurboST5 View Post
    The spacer plates look significantly different between the l36 and l67s. Everything under $100 looks to be for the l67. I drive it about an hour each way to the track so race gas would add up pretty quick. I also put some street miles to work and such.
    I agree the intake does look thin and brittle. I removed it today to get a close look at it. I found a unused vac port on the throttle body I am going to try to make work. The location is good but it is a little close to the tps. The whole is also slightly larger than what I need at 3/8" the recommended drill size for the 1/8npt tap is 11/32. I will see when the kit shows up.
  5. #5 Re: Meth/water injection with l36 intake.
    Daytona, florida
    Quote Originally Posted by danomite02 View Post
    What nozzle are you running? Are you running 50/50 or straight meth? Thanks for the responses guys.
  6. #6 Re: Meth/water injection with l36 intake.
    Jul 2011
    CT
    im on a 10gph nozzle now. Im twincharged, trying to keep the heat from the blower at bay... 50/50 mix by volume of VP M1 and distilled water.
  7. #7 Re: Meth/water injection with l36 intake.
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by mkyota1 View Post
    only difference that is significant is the bore size which is not a big deal. all the other differences shouldnt matter either. the bolt hole pattern is the same. post a link to the one you are looking at.
  8. #8 Re: Meth/water injection with l36 intake.
    Daytona, florida
    http://shop.zzperformance.com/store/...y-Spacers.aspx. This is the l67.
    http://shop.zzperformance.com/store/...dy-Spacer.aspx. this is the l36. I know the pattern is the same it just looks like it would effect flow. Maybe not. I'm pretty sure I will be able to use the existing hole in the t/b. I will keep you guys posted.
  9. #9 Re: Meth/water injection with l36 intake.
    Kemmerer, Wyoming
    are you running the L67 heads with the N/A upper intake manifold? you could use some of the injector ports to do a direct port meth or nitrous setup .
  10. #10 Re: Meth/water injection with l36 intake.
    Daytona, florida
    L36 heads on it.
  11. #11 Re: Meth/water injection with l36 intake.
    Kemmerer, Wyoming
    if you feel motivated enough you could swap those heads for L67 or L32 and then do a direct injection of some nitrous or methanol.
  12. #12 Re: Meth/water injection with l36 intake.
    Daytona, florida
    I was able to use an unused vacuum port to mount the nozzle. I opened it up so that it doesn't restrict flow much. I think it will work fine and free is always good.
  13. #13 Re: Meth/water injection with l36 intake.
    Apr 2015
    Columbus, OH
    That's pretty slick. Nice work.
    Top Swapped 01 Imp
  14. #14 Re: Meth/water injection with l36 intake.
    Daytona, florida
    Quote Originally Posted by bandook View Post
    Thanks man.
  15. #15 Re: Meth/water injection with l36 intake.
    Daytona, florida
    Here is what it started as.
  1. water/meth injection kit. how good is it?
    By kking89 in forum General Tech Discussion
    Last Post: 03-29-2015, 12:00 PM
  2. WTB: Meth Injection KIT
    By fri3dchick3n in forum Wanted To Buy - Parts
    Last Post: 03-01-2013, 04:48 PM
  3. Meth Injection Kit
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2012, 12:41 AM
  4. DIY Meth injection ?'s
    By TEK310 in forum General Tech Discussion
    Last Post: 06-23-2012, 01:23 PM
  5. Intercooling or Meth/Water Injection
    By Ttypel67 in forum General Tech Discussion
    Last Post: 06-21-2010, 01:07 AM
