Thread: help with launching
Results 1 to 4 of 4
  1. #1 help with launching
    Dec 2011
    colorado
    Hi guys I need some help trying to figure out how to launch this car. I have a GTP with a stattama turbo kit on it. I've got bigger brakes front and rear. And the smaller brake booster. My problem is all the lag I am having. I cannot get this thing to build boost sitting at the line. I will sit there holding the brakes and when I'm about to to get into the boost my brakes won't hold and I roll forward some. I never had this problem on my old setup but that was stock size brakes and booster. I know I have to be doing something wrong or don't have stuff set up just right or something.
    How does everyone brake boost at the line to get good launchs? Any tips or troubleshooting help would be awesome. Oh and I have 3250 stall in it as well.
    Thanks
  2. #2 Re: help with launching
    Nov 2012
    Erlanger, KY
    Use a momentary switch, with the IAT sensor deal. So when pushed in, see's no reading. Then use the IAT table to drop you timing down to nothing.
    No timing, car won't be making power, so can build up boost. Then let go of the button when you let off the brake.
    I have my PCM setup to where regular timing tables are setup to drop timing in a certain RPM range and PEvsTime table to richen up the fuel, to kick turbo some in the ass.
    Worked well on my 3000 stall, stock brakes, and small booster.
    I can launch at 10psi now... But the method I use, with no switch, leaves me a small window to launch in.. to low of an RPM.. and it bogs... to high of an RPM, and car lurches forward and
    will just smoke show the tires...
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  3. #3 Re: help with launching
    Dec 2011
    colorado
    Thanks man I'll look into that. I need to do something it's driving me nuts
  4. #4 Re: help with launching
    Approved Vendor FurchesPerformance's Avatar
    Jun 2014
    Springfield MA
    Extremely good suggestion above for a quick and effective solution.
    What size exhaust housing is on the turbo? What size is the compreesor/turbine wheel? Are you still sitting on a stock rear manifold with a gate perch?
    Brandon
    Furches
    2008 -Dark Slate Metallic- Grand Prix GXP
    2005 -Dark Cherry Metallic- Grand Prix GXP
    2005 Monte Carlo SS Supercharged
  1. Launching a gtp help/advice
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 03-16-2011, 10:22 AM
  2. Tranny slipping? Launching probs..
    By 9ordohz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2011, 04:28 AM
  3. Launching tips?
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 10-23-2009, 08:23 PM
