Thread: New double roller installed
Results 1 to 20 of 25
  1. #1 New double roller installed
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    We are installing a new cam and with it a double roller chain. We got the new cam installed but with the timing chain we ran into some issues.
    A spacer came with the chain and if we put it on the crankshaft the chain is not straight at all and wont roll smooth. Are we missing a step? Also the chain tensioner isnt made for a double chain is there a new one I will have to buy for the extra width?
    Last question I got, the front cover isnt going on all the way I never read about having to get a new one, we checked everything over its just not wanting to go on straight can anyone help??
    May not be the correct topic area but its for a turbo build.
  2. #2 Re: New double roller installed
    Apr 2015
    Columbus, OH
    For the cover you'll need to stack gaskets or machine it.
    From zzp:
    The single row set is a direct drop in replacement for the factory timing set. Simply remove the factory crank and cam sprockets, with the chain, transfer the cam positioner magnet from the factory cam sprocket to the new roller sprocket, and install the new timing set.
    To run the *double roller, the balance shaft gear must be removed. To save additional weight the balance shaft can removed altogether but this requires plugging the rear oiling hole. The Rollmaster has a much tighter fit, so the timing chain tensioner is no longer used.
    Double chain sets are required for engines running valve springs higher than 105 pound.
    *Due to potential front cover clearance issues on some cars, we recommend running (2) front cover gaskets -or- (1) ZZP garlock front cover gasket and our machined oil pump cover when installing the double roller.
    The Cam position sensor magnet pushes in from the backside in the hole that is recessed.
  3. #3 Re: New double roller installed
    Jan 2014
    United States
    Theres threads about installing a double roller. They say you need to remove certain parts, and that you need a new machined oil pump cover.
  4. #4 Re: New double roller installed
    Jun 2014
    United States
    Thanks guys I got the machined oil pump and the gasket ill just have to work it in there thanks a lot.
  5. #5 Re: New double roller installed
    Make sure you have the chamfer on the back of the crank gear corrected at a minimum.
  6. #6 Re: New double roller installed
    Bastard Reptile's Avatar
    Kansas City, MO
    The fact that they still sell it like this bothers the crap out of me.
  7. #7 Re: New double roller installed
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by Reptile View Post
    They sell it like that because an Australian company makes the double roller and it's correct for the Ausssie 3800
    Obviously not worth the time and money to them to sell a U.S. Version.
  8. #8 Re: New double roller installed
    Kemmerer, Wyoming
    Quote Originally Posted by 231FUN View Post
    it would take so little effort for them to correct the problem with the camfer.
  9. #9 Re: New double roller installed
    Kansas City, MO
    I'm aware of that....I'm saying that when zzp sells them, they should be sold so that you don't have to modify them more to make it right.
    I figured this out close to 8 years ago, after my crank gear split in half.
    It takes 5 minutes to machine them, there's no reason for it IMO.
  10. #10 Re: New double roller installed
    Dec 2011
    Ontario,Canada
    Yeah I figured you were... Obviously not worth the time and money for zzp to do it either,people keep buying them as is.
  11. #11 Re: New double roller installed
    Nov 2011
    NY
    This is candidate for the LIKE button!
    lol...
    what bothers me even more is someone modding without doing all the necessary research first! There's got to be hundreds of links including YouTube vids on the DOUBLE ROLLER add to a 3800. So come on!... Really?
    sorry OP, but you deserve it!
  12. #12 Re: New double roller installed
    Jun 2014
    United States
    Quote Originally Posted by coolone View Post
    lol...
    Im fine with you being angered over me not looking it up but I feel I get more info out of experiences from others than a youtube video that can br less informative on what needs to be done.
  13. #13 Re: New double roller installed
    Nov 2011
    NY
    Quote Originally Posted by Loftus1995 View Post
    Not angry, and it's just that the information is really readily available on a double roller install, the benefits, the hazards. Bottom line is what LIFT are you planning to utilize on the build? If not high lift, you may not need it at all... You mentioned a cam, but nothing else. It's all relative...
  14. #14 Re: New double roller installed
    Kemmerer, Wyoming
    take the rollmaster double roller crank gear to the machine shop with the stock crank gear and have them match the camfer of the stock crank gear.
  15. #15 Re: New double roller installed
    Kansas City, MO
    This is what could happen if you don't machine the gear like it NEEDS to be...The only thing that held it together was the oil pump. I drove it home 40 miles like this, and it's a wonder that I didn't lose an engine. Made a LOT of noise.
    This is with a machined cover, and double gasket. It'll still rub...
  16. #16 Re: New double roller installed
    Nov 2011
    NY
    Ouch! I remember those pics
    What's good to eat? (Disk)... Lolz
    How many of those million recipes have you tried?
  17. #17 Re: New double roller installed
    Kansas City, MO
    LOL....I honestly don't remember.
    Most of it was crap that I won't eat anyway, we've moved on to summer grilling/smoking now. I've got my own for those.
  18. #18 Re: New double roller installed
    hangover park IL
    the gear splitting is a major flaw of the old rollmaster kits with the oil pump drive reliefs causing an excessively thin wall thickness at the 9 keyway slots....the chamfer hitting the crank fillet and mushrooming the gear just helps start and propagate the fractures. its the primary reason RM bought out JP's line with their two piece crank sprocket.
    proper machining is always good but it seems the two piece does handle the incorrect fitment quite well.
    I remember pricing it out to buy 10 sets and machine em all but I don't see many folks wanting to spring for nearly an extra 100$
    if I got my lathe up and running I could probably do it but its not worth my time as it were lol
    well aside from doing it for me I did my part via years of checking and even contacting s fellow buick nut down under on an obscure invite only talldeck commodore forum and sharing the modsand pics on Cgp
    for some reason the aussie cranks are slightly different.
    that said at least the 442's new rear engine will finally prove my iwis/jp gear theory right or not but I believe it will work just fine.
    with the properly machined crank and cam sprocket you get the correct stack height at the crank (belt grooves are in the correct spot), a bit looser clearance from the magnet to cam sensor (no change to sensor effectiveness). and you get at least .020+" pin to cover clearance with the paper cover gasket and the steel felpro (block side of paper gasket) from the cs9917 kit...with the stock cover.
    it might still be smart to pop the pump and inspect it. much like the original buicks the aluminum timing cover/pump housing wears down and you can get quite a bit of slop...yet another reason a good used shortblock is desirable...at least the pump and cover are likely to be fine along with a good used crankshaft.
    ~James~ Psychotic Gearhead
  19. #19 Re: New double roller installed
    Buffalo
    Here's how mine turned out with 1 metal gasket , 1 surfaced-ground oil pump cover (from gr8racingfool) and machined crank sprocket.
    This appears to me like it sits flush against the crank surface - if the chamfer wasn't correct its my understanding there would be a gap
    Double vs stock
  20. #20 Re: New double roller installed
    Buffalo
    Now I noticed the machining isn't as much as the stock one, but they both sit flush .....
  1. Rm double roller
    By BLUESMOKEGTP in forum Wanted To Buy - Parts
    Last Post: 04-14-2015, 03:30 PM
  2. WTB: Double roller and Stattama ST5
    By MattStrike in forum Wanted To Buy - Parts
    Last Post: 03-19-2014, 12:52 PM
  3. Should I get a double-roller?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:20 AM
  4. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
