Thread: zzp z7 turbo kit
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: zzp z7 turbo kit
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    You're not going to find a new m90. Refurbished yes, but new no. IF you go turbo then the kit will include everything(almost) new.
    If you already have a shop in mind get an estimate for both builds. It'll give you an idea of how much it'll cost for you not being patient. It's one thing if you have the money but not the time, but with you saying money is a little bit of a constraint, i would at least consider doing it yourself/with some friends.
    I have a shop near me i trust. They quoted me $1400 labor for a cam install, no parts included. That right there convinced me to do it myself. Save that money if you can dude.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  2. #2 Re: zzp z7 turbo kit
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by chrsmi1 View Post
    I've actually got one that's as close to new from GM as you're probably gonna get. It's only got about 10k miles on it.
  3. #3 Re: zzp z7 turbo kit
    Kemmerer, Wyoming
    I took my car to a local mechanic, the guy I take my car to for most of my maintenance, and he charged me 1100 for installation of heads and a cam. the hard part of a top swap is the harmonic balancer remove and install. installing the heads and supercharger would be the easy part, just time consuming. doing a top swap would be an easy way to make 300 hp at the wheels with a cam and a light port job on the heads.
  4. #4 Re: zzp z7 turbo kit
    ive said it a million times ill say it again.
    stock heads stock throttle body stock timing chain s1x cam 105# springs ti retainers tog headers gen5 sc 280+ whp on 3.4 and 330whp on 2.8 and e85.
    such simple setup.
    no need for mega buck heads no need for double roller timing chain no need for intercooler.........
  5. #5 Re: zzp z7 turbo kit
    May 2008
    Schuyler, NE
    You'll be happy with any of the lower-end cams. VS, XP, S1X, LL, etc.
  6. #6 Re: zzp z7 turbo kit
    GT Level Member Xorbex's Avatar
    Canada
    I made 291 hp on my setup and I even had plug wires backwards. Also had a canned tune at the time that was off.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  7. #7 Re: zzp z7 turbo kit
    Sep 2012
    fort Wayne, in
    I've read alittle about e85. What all goes into it? I know it's adrenalin for the car! I need to be more resourceful about people who can port out the heads. I'd want to get the s/c ported to right?
  8. #8 Re: zzp z7 turbo kit
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    You basically need bigger injectors because it requires 30% more fuel , I would say a racetronix fuel pump ( some will say stock is fine , you decide ) , change the fuel filter , and then obv a tune.
  9. #9 Re: zzp z7 turbo kit
    Oct 2012
    Albany, NY
    It burns really cold , higher octane , about 107 , helps fight knock , and you can run a lot of timing.
  1. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
