Thread: Nitrous and a Turbo?
Results 1 to 16 of 16
  1. #1 Nitrous and a Turbo?
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    I know it is a stupid question but I am honestly kind of stumped... Can you run nitrous with a turbo SAFELY. I bought a turbo kit (T67) but about a week before that I was up in the air about still doing a SC. Now that I am committed to the turbo is there a way I can still use the nitrous or is it kind of null and void? Its the proton Plus from NX, the shots vary from 35 to 250 so there is a little to work with if I can use it.
  2. #2 Re: Nitrous and a Turbo?
    SWPA
    I know plenty of people running both. Why wouldn't you be able to?
  3. #3 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    I was just afraid of having to much for the engine to handle, you think a 35 shot will be safe enough?
  4. #4 Re: Nitrous and a Turbo?
    people have sprayed up to 150 shot look on 3800pro.com at the nitrous section there. The tuning and fuel being used will be key to the engine surviving
  5. #5 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    Ill have to check that out thanks!
  6. #6 Re: Nitrous and a Turbo?
    Feb 2009
    flintnasty MI
    I run a 80 to 100 dry shot on both the 600whp+ auto cars here in flint
  7. #7 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    For injectors on e85, nitrous, and a turbo should I go with 60 or 80 pound injectors? Who I bought it from says he had 60 but after 15 pounds of boost they ran static?
  8. #8 Re: Nitrous and a Turbo?
    Need way more info than that each setup will be different when deciding when the injectors go static....... If you can find 80s id take those over the 60s if your going turbo and bottle. But that doesn't mean the 60s wouldn't work. Sooooo many variables here and unknowns about your setup.
  9. #9 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    Understood, when I get home ill type out everything im planning on doing to it.
  10. #10 Re: Nitrous and a Turbo?
    Even that's not going to help, real world trial and error will. To be safe again id rather start out with 80s especially if your using E85.
    hell ZZP sells injectors up to 160#.
  11. #11 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    Yes I may try them, I sadly now have 60# injectors to sell before I can buy the 80's
  12. #12 Re: Nitrous and a Turbo?
    Why you don't even know if the 60s will be enough, maybe they will be.
  13. #13 Re: Nitrous and a Turbo?
    Run them.. Then if you need some bigger ones upgrade.. No sense in selling what you have before you even know if your going to need something bigger..
    04 Comp G.
  14. #14 Re: Nitrous and a Turbo?
    Feb 2009
    flintnasty MI
    60s have almost been in the 9s.
  15. #15 Re: Nitrous and a Turbo?
    Jun 2014
    United States
    Thanks, just looking at the options, I just want to get it right the first time rather than having to pull something again haha.
  16. #16 Re: Nitrous and a Turbo?
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    I can get u a link to Bosch 1000cc injectors if u want to run something bigger than 80s. That's what I'm running
  1. Turbo and nitrous?
    By 97turbogp in forum General Grand Prix Discussion
    Last Post: 07-02-2014, 08:27 AM
  2. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
