Thread: Stock Headgaskets
Results 1 to 20 of 34
  1. #1 Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    how many lbs of boost have people pushed them too? i think i remember reading 22-24 lbs is max is about it. my car has head studs in it. just curious as im going to order a new wastegate with an 11lb spring so i could run upwards of 22 lbs. i currently run 18 with 18* of spark advance and havent had any issues.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: Stock Headgaskets
    Mar 2012
    NC
    Quote Originally Posted by NebTurboST5 View Post
    Run em.
  3. #3 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Run em.
    planned on it as i dont plan to tear it apart. just curious if anyone had any experience on high boost.
  4. #4 Re: Stock Headgaskets
    May 2008
    Schuyler, NE
    The guys from Canada has run up to 30 on completely stock motors. I don't think you'll have a problem especially since you have studs and your car is slow.
    Im not sure what you would switch to. I sent SCE an email to try and get info from them, but they are difficult to get ahold of.
  5. #5 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    those high performance MLS pieces of **** that were so popular for a while
  6. #6 Re: Stock Headgaskets
    SWPA
    MLS are stock head gaskets on the 3000GT/Stealth's and also DSM's. There are many, many guys running 20+ psi of boost and still lots of others running 35+ psi of boost on the factory MLS with no issues on those platforms. It's odd that the 3800 platform would have issues with them, unless there was some sort of manufacturing defect or something else causing the failures/issues.
  7. #7 Re: Stock Headgaskets
    May 2008
    Schuyler, NE
    I think stock is probably better than those.
  8. #8 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    no doubt.
  9. #9 Re: Stock Headgaskets
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Ive had MLS with less power then I have now and they blew. I then went with stock. Worked much better. I just blew my stock gaskets at 25 psi due to cracked heads and also my engine not breathing enough. I only have a rear PEM which i'm getting rid of. I have new stockers ready to be put back on.
    I forgot who but he ran 28 psi on stock gasket.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  10. #10 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by Silver2kgtp View Post
    holy **** i just realized that my car trapped almost the exact same MPH as yours. my pass was only an 11.57 though. it was a turd out of the hole.
  11. #11 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    good info thanks. i think im gonna run a 11psi spring in my car so i might turn it up to low 20's
  12. #12 Re: Stock Headgaskets
    Banned
    CT
    Sal's car didn't accelerate for the last 330' that's why he only trapped 122 lol
  13. #13 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SnowFlake View Post
    any particular reason he shut it down at 990'? i guess i was just excited. if i could get a 1.74 60' out of my car it should go at least 11.4x
  14. #14 Re: Stock Headgaskets
    Banned
    CT
    AFR was 16.0+ or something and was making no power… think he sucked the canister dry.
  15. #15 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    ouch...
  16. #16 Re: Stock Headgaskets
    Feb 2008
    NY
    Yeah the car just lost all power and fell flat. Like Nick said canister was sucked dry. E85 saved my bottom end.
  17. #17 Re: Stock Headgaskets
    Seems like stock GM gaskets are the way to go.
  18. #18 Re: Stock Headgaskets
    May 2008
    Schuyler, NE
    If you get some real tires on the front of that thing, you can cut big boy 60ft's.
  19. #19 Re: Stock Headgaskets
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    I'm gunna be running 24-25lbs on stock felpro gaskets And head studs.
  20. #20 Re: Stock Headgaskets
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i would get the gaskets from GMpartsdirect not a parts store. i have seen the felpros from a parts store fail quickly
  1. bad headgaskets from overheating
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2014, 09:52 PM
  2. any hop-ups while engine is torn apart and replacing headgaskets?
    By 05silverado4x4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-24-2012, 07:02 PM
  3. Coolant issue....headgaskets?
    By 98L36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2011, 11:55 AM
  4. Which Headgaskets?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 11:56 AM
  5. L36 headgaskets....old age..pics
    By UR LOSN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2008, 08:46 AM
