Thread: Will stock tranny hold up to turbo.
Results 21 to 40 of 41
  1. #21 Re: Will stock tranny hold up to turbo.
    I live here. UR LOSN's Avatar
    Rockford, IL
    the minute you drop to a 3.4 pulley on a blower... you have already maxxed out what a stock tanny was designed to handle.
    like what was said before...... just a matter of when.
  2. #22 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    Ya, but isn't a S/C worse on a Tranny then Turbo?
  3. #23 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    Okay called ZZP! The bolt on will work for the L32 he said it will bolt up pretty much perfect! But he said he would just sale the GEN 5 and not worry about the block off plate. He said I could get more money from doing that and it really wouldnt make a difference in hp. Sooo! Im glad I know for a fact it will bolt on. He also of course told me about the PCM. I told him what I wanted to do with the 05 ECM and he said they would just treat my car like the 05. So!! its getting closer and closer to time!! im soo excited!!!
  4. #24 Re: Will stock tranny hold up to turbo.
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    An M90 car will eat transmissions more on a launch or through a hard shift while the turbo cars make more power and tend to break things through a pull, that and because of the much higher HP that a turbo car makes and solid torque curve through each gear it is harder on the clutches. An M90 car strives on torque to get the job done and will make less HP but has more instant low end torque. Once a turbo spools that battle is over! Any way you slice it the stock trans is going to be very short lived even if all you do is spin the tires the first two gears because the chains will likely give way through a pull while in a gear. It is also going to slip pretty bad during shifts stock and if a hardpart doesnt break first the clutches will be cooked in a short matter of time. An input shaft and chain upgrade are mandatory but the trans has to be built properly to handle the power also-firmer/quicker shifts to handle the added power and this requires more than an off the shelf shift kit
  5. #25 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    I just got done looking at your site! haha. So what tranny would be the best? Also if I buy it from you do you install it or just build and sale them??
  6. #26 Re: Will stock tranny hold up to turbo.
    Fort Wayne, IN
    All of my transmissions are custom built to match the car and power level you are or plan to run. You can send me an email for specifics on pricing but you are going to need an upgraded input shaft, single chain conversion, and an upgraded torque converter would also be a good idea with a turbo car so the stall speed will work better to allow the turbo to spool and also to handle the extra power you will be making. I do very limited installs depending on my schedule but it is an option and I also have a local hotel I use for out of town customers at a discounted rate.
  7. #27 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    Okay!! Well it will be around Jan mid Feb when I start to get everything. I was just in Cloverdale, IN about 3 weeks ago. But when it gets closer to time and I get everything in line I will send you a list of all the specs.
  8. #28 Re: Will stock tranny hold up to turbo.
    GTP Level Member David99GTP's Avatar
    Florida
    Good info, I was on the same path and the general opinion was not if but when. 400hp is gonna be the death of your stock tranny. I have since decided to hold off on the high HP numbers and start with a solid foundation. Gonna have a tranny built for what I have planned in the future. I figure its worth the delay. Better to have a solid tranny now than a fast car broken down in the driveway.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  9. #29 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    Yes! I so agree! Like my dad said..."Ya, it will be nice to have a 400whp family car but 400WHP can't do much without a tranny" lol
  10. #30 Re: Will stock tranny hold up to turbo.
    Rockford, IL
    that would make a great slogan!
  11. #31 Re: Will stock tranny hold up to turbo.
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Why would you use your credit to buid something thats going to end up costing more in the end? Just my opinion but if I cant pay cash for it I dont need it. Unless its a transmission in my daily driver that pays the bills....but to each his or her own.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  12. #32 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    ...Im paying cash for everything..lol If it was credit I would have already had everything!
    EDIT: My 07 GP is PAID for. So my hard earn savings/income tax is going to mods.
  13. #33 Re: Will stock tranny hold up to turbo.
    Feb 2008
    Houston
    Awesome! =)
  14. #34 Re: Will stock tranny hold up to turbo.
    May 2008
    staten island,NY
    why not go supercharged? im going low 13's and trapping 104mph on a 3.4 pulley.
  15. #35 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    My car is supercharged. I also invested over 5K in my GTP just to run High 12-13s But I never ran it after I upgraded the pulley on my Whipple set up . I have never owned a turbo car and woould love to! And it would be WAY different.
  16. #36 Re: Will stock tranny hold up to turbo.
    May 2008
    staten island,NY
    well you were doing something wrong if you put 5grand into the M90 and didnt go anywhere. im $1800 into it and im in the 12's.
  17. #37 Re: Will stock tranny hold up to turbo.
    Oklahoma
    Whipples weren't cheap.
  18. #38 Re: Will stock tranny hold up to turbo.
    TDCRacing
    Guest
    sHE HAS A WHIPPLE. And where in the hell did you get a whipple from?
  19. #39 Re: Will stock tranny hold up to turbo.
    TDCRacing
    Guest
    Arrr.....
  20. #40 Re: Will stock tranny hold up to turbo.
    Nov 2008
    Searcy,Arkansas
    I ordered it about 3yrs ago from the website. I don't think they make them for the Grand Prix anymore. I paid right around 3K for it and all the supporting mods. And then I built the tranny up.
  1. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  2. anyone know why my turbo does this???
    By lilredss0287 in forum Turbo
    Last Post: 08-23-2008, 09:11 AM
  3. GP totalled, life on hold
    By Quicksilver_GP in forum Off Topic Discussion
    Last Post: 05-08-2008, 09:54 AM
