Thread: going from s/c to turbo?
Results 1 to 20 of 27
  1. #1 going from s/c to turbo?
    I’ve always been thinking about going turbo. Kinda want to set a goal of running ~380-400whp and/or be able to trap 120-125mph trap speeds. The items that are needed to go turbo im really not sure on so that’s why im posting this thread.
    I know I’d need to run manifolds, prolly P-log and welded rear (ported) manifold and of course the turbo crossover pipe. I’d need a decent wastegate along with an electronic boost controller for ease of use, a specific turbo size, and bov. I was thinking of running a gutted M90 and instead of using an I/C to try and continue to use the devils’ own alky/meth injection. Also I read that the stock L67 MAP sensor would be useless, is the air/fuel controlled via MAF sensor instead? Also the turbo needs to be oiled, is there more than 1 oil feed line and where does it tap into, the oil pan?
    No worries on the tranny as I plan on upgrading it to take the power. Can I still run on the 42.5# injectors for for my goal? Thanks in advance for your support!
    Maybe make this a sticky for newbs like me? ^_^;
  2. #2 Re: going from s/c to turbo?
    Aug 2008
    Long Island, New York
    They sell turbo kits for your car... zzp makes the z7, and also they sell the statama turbo kit... this is your best bet if you wanna make some power with a turbo.
    https://www.zzperformance.com/grand_...=410&catid=109
    https://www.zzperformance.com/grand_...=411&catid=109
    when buying these kits for a supercharged gtp you need the m90 blockoff. im pretty sure they have an option you can select on there to get that
  3. #3 Re: going from s/c to turbo?
    yes i know zzp makes kits for our cars, im just asking if theres a likelihood of piecing together a custom setup myself. if not, i can always get a used kit in the classified section on the forums, but thats all in one chunk.
  4. #4 Re: going from s/c to turbo?
    Aug 2008
    well of course theres ways to piece the kit together yourself... but it makes it harder to do usually and costs more in most cases. i would just get a kit thats already been proven to work well because turbos are really complicated systems
  5. #5 Re: going from s/c to turbo?
    SE Level Member mzendano's Avatar
    Oct 2008
    Buffalo
    the best way is to go with a new zzp kit, you get what you pay for in performence
  6. #6 Re: going from s/c to turbo?
    Jersey
    cartuning makes a nice turbo kit too. their are plenty of guys on this forum that are running way bigger turbos then in those kits. I know moderator UR LOSIN is running a gt45 turbo, which is huge.
    16' wrx sti- stock
  7. #7 Re: going from s/c to turbo?
    SE Level Member BlackGS's Avatar
    Central Jersey
    There are a few other things you have to consider when installing the turbo:
    - You need to Tee off the oil pressure sender and run a feed line to the turbo.
    - You need to run a return drain line from the turbo to the oil pan.
    - The MAF will have to be modified, or an AFC will have to be installed.
    - You may need a smaller brake booster if the downpipe is 3", with 2.5" it should be ok.
    - The PCV system will have to be modified to run non-metered air. The simplest way is to put a breather on the valve cover and block the stock PCV passages, but the best setup is to run a filter.
    - The EGR must be removed, and existing passages blocked.
    - You will definitely have to do some tuning.
    Piecing together the system can be done, but as mentioned, it will be a lot easier to buy one of the available kits.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  8. #8 Re: going from s/c to turbo?
    SE Level Member f0rge's Avatar
    Nov 2008
    toronto
    i have an intercooled cartuning kit at 10psi, and i'm pretty happy with the kit as a whole
  9. #9 Re: going from s/c to turbo?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 2000GTP View Post
    Actually piecing together a kit will come out to be a LOT less than just buying a kit from ZZP or wherever. Ya it will be a little bit more of a hassle but to save like $1000 dollars or more just by piecing together a kit is well worth it IMO.
    Just wondering but why are you only running that kit at 10 psi? Hell my 3.4" pulley hits 10 psi. Your kit's intercooled, you should be able to run quite a bit more boost than that.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  10. #10 Re: going from s/c to turbo?
    Barksdale AFB, LA
    Quote Originally Posted by Smokin2000gtp View Post
    But he makes quite a bit more power on that 10PSI. And he has higher compression resulting in more caution needed with boost levels.
    2009 Subaru Impreza WRX STI
  11. #11 Re: going from s/c to turbo?
    Jul 2008
    Dekalb, IL
    Ah I didn't see that he had it on a GT.
  12. #12 Re: going from s/c to turbo?
    Nov 2008
    toronto
    honestly cause i dont need the power, and to save my half broken tranny till i can afford a proper rebuild. the car used to be at 15psi
    there's a big difference between S/C and turbo psi, my GTP runs at 10psi as well and there's no question which car makes more power
    Quote Originally Posted by Sabrewings View Post
    actually my car is a bit odd, after the engine blew it was rebuilt with L67 pistons (but still has L36 heads)...so it's medium compression?
    98 GTP - supercharged
    01 GT - turbocharged
  13. #13 Re: going from s/c to turbo?
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by f0rge View Post
    Ah gotcha, a broken tranny is definitely no good. Ya I know a Turbo will always make quite a bit more power at the same psi since you're using exhaust gases to create the boost instead of power from the crank, I was just trying to point out that if my car can support 10psi with it being supercharged and non-intercooled that you should be able to run quite a bit more boost than me with your setup.
  14. #14 Re: going from s/c to turbo?
    Barksdale AFB, LA
    I believe most of the compression comes from the rod length and not the pistons.
  15. #15 Re: going from s/c to turbo?
    Nov 2008
    Searcy,Arkansas
    Didn't want to start a new thread on this when there is already one done so I thought I would just put this here! Sorry Admin if I did it wrong..And also this might help the guy out some!
    The zzp Turbo kit I am looking at as everything I need! You dont have to tap into the oil so thats a plus! I dont have the turbo yet but I have been reading it and hope in Feb I can get it! Here is what I have found on the "hot side" piping is a new cross over (That comes with the kit) and a down pipe (that comes with the kit) and welding it to the stock exhaust And the "cold side" Im prolly going to go with the m90 block off plate/intercooler and the only pipe I will need is from the turbo to the TB. And on the exhaust manifolds I was thinkin about getting front and rear P-Logs. Since they are a little bit more turbo friendly. Okay! So again I DO NOT HAVE IT!! lol Just some research and the plan I wanna take.
  16. #16 Re: going from s/c to turbo?
    hmm interesting facts here guys, thanks. if i ever piece or get my hands on a turbo kit the only pieces or areas i still would have issues or confused about is the oil lines going in/out of the turbo.
    i can tap into the feed line with where the oil pressure sender is correct? what about tapping into the oil pan, wouldnt i need to drill/tap a hole for it?
    i can block the pcv passage area where the tb is at with metal epoxy? and run a breather/catch can off the valve cover?
    i might skip the i/c and just continue running my alky with a larger nozzle.
    the tranny's been rebuilt by trannyman with 3.29s, 300M input shaft and a 1" gm chain
    does the MAP sensor at this point switching from s/c to turbo obselete then?
    if anything i'll run at a max 14-15psi since i dont want to blow my 160K mile headgaskets
    what else is there that i havent covered yet?
  17. #17 Re: going from s/c to turbo?
    I live here. UR LOSN's Avatar
    Rockford, IL
    The oil return line can be put where the oil level sensor is in the front of the oil pan. you can get an adaptor that just screws into the pan....and run the dain directly to it. You'd just have to delete the oil codes out of the PCM.....and keep an eye on oil level the old fashioned way..................
  18. #18 Re: going from s/c to turbo?
    can someone post a pic of where the oil level sensor is at? is that where when u install an oil perssure gauge and screwin the oil sender unit? if so, u get a "T" fitting and both lines from the "T" fitting would supply both the feed and return line for the turbo correct?
  19. #19 Re: going from s/c to turbo?
    TDCRacing
    Guest
    I beleive the oil pressure sensor is located on the Oil neck housing. Wich would be where you screw the oil filter on to. If you go under the car from the from the oil level sensor is on the front side of the oil pan (twards the radiator) on the side of the oil pan in the middle.
  20. #20 Re: going from s/c to turbo?
    i read that swapping to a turbo the original/factory pcv system needs to be blocked or plugged and run something like a valve cover breather or a valve cover breather with a hose and have it circulated back to the pre-turbo inlet. why is that? should i epoxy the hole for the pcv that goes into the throttlebody from the m90 casing?
  1. zzp z7 turbo
    By rodman in forum Turbo
    Last Post: 12-29-2008, 05:54 AM
  2. Turbo L36 vs. Turbo L67
    By 99prixgt in forum Turbo
    Last Post: 09-27-2008, 12:42 PM
  3. Turbo my Gp GT?
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-11-2008, 11:41 AM
  4. anyone know why my turbo does this???
    By lilredss0287 in forum Turbo
    Last Post: 08-23-2008, 09:11 AM
  5. Turbo Gxp!!!
    By PshnLck18 in forum Turbo
    Last Post: 08-18-2008, 12:23 AM
