Thread: going from s/c to turbo?
Results 1 to 20 of 27
  1. #1 Re: going from s/c to turbo?
    SE Level Member f0rge's Avatar
    Nov 2008
    toronto
    Quote Originally Posted by Smokin2000gtp View Post
    Just wondering but why are you only running that kit at 10 psi? Hell my 3.4" pulley hits 10 psi. Your kit's intercooled, you should be able to run quite a bit more boost than that.
    honestly cause i dont need the power, and to save my half broken tranny till i can afford a proper rebuild. the car used to be at 15psi
    there's a big difference between S/C and turbo psi, my GTP runs at 10psi as well and there's no question which car makes more power
    Quote Originally Posted by Sabrewings View Post
    But he makes quite a bit more power on that 10PSI. And he has higher compression resulting in more caution needed with boost levels.
    actually my car is a bit odd, after the engine blew it was rebuilt with L67 pistons (but still has L36 heads)...so it's medium compression?
    98 GTP - supercharged
    01 GT - turbocharged
  2. #2 Re: going from s/c to turbo?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by f0rge View Post
    Ah gotcha, a broken tranny is definitely no good. Ya I know a Turbo will always make quite a bit more power at the same psi since you're using exhaust gases to create the boost instead of power from the crank, I was just trying to point out that if my car can support 10psi with it being supercharged and non-intercooled that you should be able to run quite a bit more boost than me with your setup.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: going from s/c to turbo?
    Barksdale AFB, LA
    I believe most of the compression comes from the rod length and not the pistons.
    2009 Subaru Impreza WRX STI
  1. zzp z7 turbo
    By rodman in forum Turbo
    Last Post: 12-29-2008, 05:54 AM
  2. Turbo L36 vs. Turbo L67
    By 99prixgt in forum Turbo
    Last Post: 09-27-2008, 12:42 PM
  3. Turbo my Gp GT?
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-11-2008, 11:41 AM
  4. anyone know why my turbo does this???
    By lilredss0287 in forum Turbo
    Last Post: 08-23-2008, 09:11 AM
  5. Turbo Gxp!!!
    By PshnLck18 in forum Turbo
    Last Post: 08-18-2008, 12:23 AM
