Thread: IAT sensor location turbo?
Results 1 to 11 of 11
  1. #1 Re: IAT sensor location turbo?
    I live here. UR LOSN's Avatar
    Rockford, IL
    Thanks guys!!
  2. #2 Re: IAT sensor location turbo?
    SE Level Member Sinister Drag Designs's Avatar
    Jacob you should not even be thinking about a IAT sensor with your build.
    Hook it up to a happy knob or an ICCU.
    Run a real Air temp sensor with a NPT end and thread it into the IC piping or UIM.
    A dual temp gauge for before and after IC temps would be ideal.
    Your going to have to scale the MAF down at somepoint most likely with an AFC so could just get the ICCU and that would take care of the IAT. Or you could run the Lq4 sensor with the built in IAT. The LT1 Style maf is only going to give a little headroom over the lq4 so i wouldnt throw out the idea of using it.
  3. #3 Re: IAT sensor location turbo?
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Quote Originally Posted by Sinister Drag Designs View Post
    The truth.
    This man speaks it.
    I let my IAT get melted to my togs, and then deleted all the codes for it. No issues.
    Lumpy Gen 3
  4. #4 Re: IAT sensor location turbo?
    SE Level Member Pimp Prix's Avatar
    Dec 2008
    Miami, Fl
    if you do decide to keep the IAT- try this out:
    ClubGP Message Forum troubleshooting
  1. Custom Sub Box Location
    By HOPPY in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2008, 12:09 PM
  2. Name this Part and location?
    Last Post: 06-24-2008, 08:37 AM
  3. pcm location
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-08-2008, 03:46 PM
  4. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
