Thread: help with my turbo build please.....
Results 1 to 3 of 3
  1. #1 help with my turbo build please.....
    SE Level Member Bino0527's Avatar
    Stockton ca
    hello every one. to start off i got a 97 gtp. i put in a zzp z7 turbo kit. i sent out my pcm to intense to tune fro the turbo 60lb lb injectors, the lt1 maf, ported tb, tep tranny, 160 stat, 103al, i turn on the car and it starts up the afr is reading 14 then it just starts to drop and goes to 10 and starts running bad. starts to shake and a funny smell starts to come out the tail pipes, i cant build no boost at all and it shuts off unless i give it gas but i soon as i let go the gas it turns off the revolutions dont go past like 3k. any ideas or help would be very welcome thank you.
  2. #2 Re: help with my turbo build please.....
    Check your O2 and map readings. Either can do this.
  3. #3 Re: help with my turbo build please.....
    Feb 2009
    flintnasty MI
    I would unplug the o2 sensor for now.
  1. s/c build or dump for turbo?
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2012, 06:22 PM
  2. Turbo build. Run and tell that.
    By Wotgtp in forum Turbo
    Last Post: 05-25-2012, 04:08 PM
  3. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  4. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
