Thread: Adding More Boost Z7 Kit
Results 1 to 20 of 27
  1. #1 Re: Adding More Boost Z7 Kit
    Feb 2009
    flintnasty MI
    IIRC, run a vac line to the bc, follow the arrows, then from the bc to the bottom nipple on the wg. The upper nipple needs to be vented to the atmosphere
    Most boost controllers should be adding pressure to the top port to emulate more spring pressure. Its the most consistant way to add boost.
    Meth is a great idea... You won't need 60s unless you're aiming for over 400whp and you can leave everything else stock.
    Meth is a horrid idea. A good intercooler is cheaper, easier, and 10000x more reliable. 60# injectors will take 93 octane to well over 500whp. 42# will work fine up to about 450whp
    Considered Northstar TB but heard they are sort of tricky with their response and road manors. If I jump to large injectors and TB, is my fuel economy really going to suffer or will those improvements only really benefit the WOT overall output and not effect the MPG's?
    Nothing is going to decrease fuel economy other than possibly a giant cam... even then its mostly because people are dumb. I run a stock throttle body to well over 700hp.... it works fine.
    Running stock in-tank fuel pump with no issues now,
    That you know of. I imagine the only thing holding you back from even 300whp is a fuel pump. Go OVERKILL on a fuel setup and you can easily go up to 16/17psi of boost without making a single other change.... I put down 440whp with excatly your setup on a ST2 cam years ago. I was able to turn it up after a giant IC was added to about 19psi and put down 505whp.
  2. #2 Re: Adding More Boost Z7 Kit
    Banned
    Jun 2012
    Sacramento CA
    You have a poor attitude and some of your info is bias/wrong. OP I would take what darkhorizon says with a grain of salt.
    I'm interested to hear your results when you start upping the boost! 9psi is barely working things!
  3. #3 Re: Adding More Boost Z7 Kit
    I run a stock throttle body to well over 700hp.... it works fine..
    Dyno sheet?
  1. Adding HUD and a DIC to your 97-03 GP
    By $03gp/gt$ in forum How To Write-Ups/Tech Tips
    Last Post: 10-12-2015, 07:25 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Adding HUD ??
    By aries83 in forum Visual/Body Modifications
    Last Post: 03-16-2009, 07:45 PM
