Thread: turbo info
Results 1 to 8 of 8
  1. #1 turbo info
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    Ok I know gtp runs like 7-8 psi of boost from the sc. I was wanting to know if I would be able to switch over to a turbo setup and run around the same amount of boost. I know sc vs turbo boost is different. Maybe alittle less boost from the turbo. I know turbos are more efficient. What would I need fuel,spark,and tuning wise?
    With that low of boost I wasn't going to worry about a intercooler
    All info is wanted and needed thanks
  2. #2 Re: turbo info
    Ohio
    youll be spending a pretty penny to turbo it. bout 3 grand said and done
  3. #3 Re: turbo info
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    More than that Mike. You need a built trans to run turbo, otherwise you'll blow through stock tranies way easily.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  4. #4 Re: turbo info
    marshalltown, iowa
    I thought about that and I have a friend that is a certified ase tranny builder. I was going to have him build me one with better gear chain,hardened input and 4th gear shaft, shift kit
    Stock specs for these trans isnt good enough.
  6. #6 Re: turbo info
    Texas
    Quote Originally Posted by sdenton8 View Post
    Sure you can run that same amount of boost. You put "X" PSI spring in the wastegate then you can control more boost from there with a boost controller. FWIW most just do a 10 PSI spring and then when they are ready, increase boost from there. You can easily run a turbo kit without the intercooler if you want. It's just going to limit you on how much boost you push, but sounds like you just want to get in the game and work from there. That's a good starting point.
    You are going to want at minimum 42lb injectors which will limit you roughly to 400ish flywheel horsepower. With that it would be a good idea to at minimum put a better fuel pump in there such as a racetronix.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: turbo info
    marshalltown, iowa
    Well the tranny will be built with parts from triple edge and have my buddy do it to save on labor.
    I just want to run 7-8 psi on a turbo and see what I can make with that vs the sc. The sc will be eliminated so that drag on the motor will be gone and free up power.
    Sounds like I would be good with the 42# injectors cuz I don't plan on going that high for power. I can get a wastegate and Bov no problem. Oil line and other parts from zzp and I got another friend that has a turbonetics t3t4 I can get. I was looking at the walbro 255 pump for fuel.
    What could I do for tuning? I know I could get a pcm from zzp
  8. #8 Re: turbo info
    new britain, ct
    to get the most power and run the safest, a custom tune is always the best.
    the problem with canned tunes is that they are pretty generic. they arent in YOUR car tuning to your EXACT specs, and they cant monitor everything. to get the most power while remaining safe a custom tune is needed.
    07 Black GXP.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Need Some Turbo Info Here
    By GMR Badass in forum Turbo
    Last Post: 06-08-2012, 11:19 AM
  3. Need some turbo info.
    By TDCRacing in forum Turbo
    Last Post: 01-27-2009, 07:12 AM
