Thread: Need help with my turbo build
Results 1 to 19 of 19
  1. #1 Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Alright i have a garret m24 a/r 60 turbo with a tial f38 wastegate. I will have a custom crossover and a custom DP. I will get a BOV in the future. But im not worried about that. What im worried about is that i need to figure out how to layout the vaccuum lines. I want jave a BC right away but maybe in the future. This whole project is being done on a 06 3.8l N/A. If anyone one could help that would be greatly appreciated.
  2. #2 Re: Need help with my turbo build
    Feb 2009
    flintnasty MI
    You need a 05 pcm thats for sure... as you probably cant tune the 06.
    Vac lines are easy... leaving everything stock works fine, run one of them to the bottom of the wastegate for your boost control. There are a few types of boost controllers, would have to know what style you are using.... I suggest the regulator type (turbonetics style), that go to the top port of the wastegate. They just use regular boost reference to go straight to the top of the wastegate with the regulator in line.
  3. #3 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    I know about the pcm too. But would i need a boost controller if my wastegate has a 9 psi spring in it. I dont want to run much higher than 9. I now understand the wastegate vac but what about the BOV?
  4. #4 Re: Need help with my turbo build
    Feb 2009
    flintnasty MI
    bov needs to be able to see engine vac, thats about it. Just give it a line from something behind the throttle blade.
  5. #5 Re: Need help with my turbo build
    Feb 2009
    flintnasty MI
    got any pics? How much do you have invested? Injectors?
  6. #6 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Well i just ordered 60# injectors. But would i need any other supporting mods? Ill upload pics later tonight because there on my computer at home.
  7. #7 Re: Need help with my turbo build
    Feb 2009
    flintnasty MI
    I would suggest a bunch of fuel pump upgrades.
  8. #8 Re: Need help with my turbo build
    Texas
    I'm running a turbo smart boost controller and can't adjust boost. I'm sure I might have the boost controller hooked up wrong.
    My vacuum goes like this:
    Bottom wastegate to MBC
    MBC to T fitting
    BOV to T fitting
    Top waste gate to T fitting
    T fitting out to top port of M90 case
    In other words everything is connected to the t fitting then goes to the top port of the M90 case. Doesn't matter how many clicks I do on the MBC it doesn't go above wastegate spring.
    Any suggestions being stuck on 11 PSI sucks
    It's a CT kit...
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Sorry that the pictures are huge but I'm still trying to figure out how to use this forum. But anyways I'll add another pic tomorrow about the vac line. Anyways what I would need for this build would be:
    turbo
    wastegate
    BOV
    Oil lines
    vac lines
    injectors
    bigger fuel pump
    piping
    Would I need anything else, and btw do you know how long the stock tranny would last or should I upgrade right away.
    Thanks for all your help.
  10. #10 Re: Need help with my turbo build
    Texas
    I wouldn't even bother with the stock tranny if you can afford a built one. The stock trannys don't hold up to alot of abuse. They can be hit and miss sometimes but most will end up taking a dump.
    I would suggest at minimum 60lb injectors. 42's don't cut it and I wish I would have just gone with the 60lbers.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Can i tee into anywhere behind the MAF?
  12. #12 Re: Need help with my turbo build
    Feb 2009
    flintnasty MI
    I always suggest T'ing in behind the throttle blade... That port on top of the PCV valve is just the go-to port for stattama inspired turbo stuff... Its what I have always done anyway..
  13. #13 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Are all the vac lines supposed to be all linked together, and do i have to have a BC?
  14. #14 Re: Need help with my turbo build
    Texas
    Any thoughts on my vacuum setup(previous post) on why I can't up the boost?
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: Need help with my turbo build
    Ohio
    lol daves car...it was so nice
  16. #16 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    @ txslow6
    Refer to the picture diagram i posted.
  17. #17 Re: Need help with my turbo build
    Jan 1970
    Maquoketa, Iowa
    The only downfall to having everything T'd into the same vac source is that if it develops a leak or a hose blows, you lose everything, including the wastegate's ability to regulate boost, then boom.
    Wastegate and BOV should each have their own source of vac, but it isn't always a perfect world.
    How close does that crossover setup come to the TB or are you going to be going with a F-body or stattama passenger style tb setup?
  18. #18 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Well im trying to figure out which way would be the easiest and the most reliable. Im leaning towards the way the picture diagram is but not %100 sure.
    Thanks for all your help guys.
  19. #19 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Could i just hook up my wastegate to a charge pipe and then just hook up the BOV to the place where the TEE is in my diagram posted above?
  1. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  2. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
  3. Build your own turbo headers
    By Deimos in forum General Tech Discussion
    Last Post: 01-23-2011, 10:22 AM
  4. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
