Thread: Need help with my turbo build
Results 1 to 19 of 19
  1. #1 Re: Need help with my turbo build
    Texas
    You need a 05 pcm thats for sure... as you probably cant tune the 06.
    Vac lines are easy... leaving everything stock works fine, run one of them to the bottom of the wastegate for your boost control. There are a few types of boost controllers, would have to know what style you are using.... I suggest the regulator type (turbonetics style), that go to the top port of the wastegate. They just use regular boost reference to go straight to the top of the wastegate with the regulator in line.
    I'm running a turbo smart boost controller and can't adjust boost. I'm sure I might have the boost controller hooked up wrong.
    My vacuum goes like this:
    Bottom wastegate to MBC
    MBC to T fitting
    BOV to T fitting
    Top waste gate to T fitting
    T fitting out to top port of M90 case
    In other words everything is connected to the t fitting then goes to the top port of the M90 case. Doesn't matter how many clicks I do on the MBC it doesn't go above wastegate spring.
    Any suggestions being stuck on 11 PSI sucks
    It's a CT kit...
    85 Corvette
    01 TA
    03 Z06
  2. #2 Re: Need help with my turbo build
    GTP Level Member
    Sep 2011
    Motown
    Sorry that the pictures are huge but I'm still trying to figure out how to use this forum. But anyways I'll add another pic tomorrow about the vac line. Anyways what I would need for this build would be:
    turbo
    wastegate
    BOV
    Oil lines
    vac lines
    injectors
    bigger fuel pump
    piping
    Would I need anything else, and btw do you know how long the stock tranny would last or should I upgrade right away.
    Thanks for all your help.
  1. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  2. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
  3. Build your own turbo headers
    By Deimos in forum General Tech Discussion
    Last Post: 01-23-2011, 10:22 AM
  4. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
