Thread: looing my license.... turbo charge??
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: looing my license.... turbo charge??
    Kansas
    Look dude, were not trying to be asses about it, well some of us are, but unless you really know what your doing, don't turbo.(Run on sentence from hell) If you want a little more out of your GT, top swap it. Find someone that knows how to tune and tune it.
  2. #22 Re: looing my license.... turbo charge??
    Feb 2009
    flintnasty MI
    Uh, for the record, if you did a ebay turbo setup (not really as bad as it sounds) and did the hot side yourself, you could be out the door for well less than $1000 and have a fairly nice (probably not nice looking) setup.
  3. #23 Re: looing my license.... turbo charge??
    Jan 1970
    Maquoketa, Iowa
    Well no ****, but 80% of the people here have never welded something before, nor own one or even know a friend that can weld for them, then if they do, that friend doesn't even know how a wastegate functions. That $1,000 will not go far if there is no knowledge to begin with.
  4. #24 Re: looing my license.... turbo charge??
    Kansas
    Quote Originally Posted by FoSHO99 View Post
    Agreed. I can weld, know where to use a welder, but doing a turbo setup... no idea.
  5. #25 Re: looing my license.... turbo charge??
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Turbo setups arent all that complicated.....they're actually pretty primitive in design. Like Dark said, he probably could get out of the door for less than 1k. **** he could run low boost and no ic, all he would have to worry about is the hotside. He would still be faster than a standard top swap. If I had to choose I would choose going turbo. Top swap is okay but the potential is always greater for a turbo, and if he wants he can get a built trans and all he has to do is turn the boost up and get tuned.
    Maximum Boost--Read it to understand if you can weld.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  1. Twin charge, Turbo, or build up the Super charger?
    By AdamBall in forum Off Topic Discussion
    Last Post: 04-29-2010, 12:19 AM
  2. core charge for transmission?
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2008, 01:30 AM
  3. Core Charge?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 07:19 PM
  4. PCM core charge
    By MTXGTP in forum Off Topic Discussion
    Last Post: 01-23-2008, 12:36 PM
