Yeah, I think I'm gonna go pretty much stock on the Regal.
Keep list (Regal):
1. Window tint, tinted tails, headlights.
2. L67 (26,800 original miles), stock snout and 3.8" pulley
3. Pioneer CD, MP3 player and speakers.
4. Stock front manifold, ported rear manifold
5. Fuel pump re-wire.
6. Plug wires.
7. TransGO Shift kit (set to hard)
8. 1.6" drop lowering springs.
Sell list (Regal):
1. 3" custom dual exhaust w/ cutout and replace with stock GTP exhaust.
2. Gutted Gen 3 blower housing with block-off plate.
3. Autometer Cobalt gauges (3) and A-pillar.
4. 255 Drag Radials on the front, Low-pro eagle F-1's on the back for $$$ and stock replacements.
Keep list GTP:
1. L32 swap (under 10,000 miles on engine)
2. ZZP 1.0 Turbo set up PCM (tuned by ZZP)
3. Z7 upgraded kit with T66 Turbo upgrade
4. Front mount Air-Air IC upgrade
5. Tial BOV
6. Tial Wastegate
7. #65lb injectors
8. PRJ fuel rails (BRAND NEW, with in 100 miles)
9. XP CAM
10. #105 Springs
11. 2.5" turbo downpipe
12. M90 Gen 3 with red snout
13. Custom 10-rib pulley system
14. Interchange 10-rib supercharger pulley
15. Relocated IAT sensor
16. Casper fuel regulator
17. Walbro fuel pump
18. High/low fan switch
19. Throttle body spacer (with nitrous port)
20. RAT engine supports
21. Poly motor mounts
22. O2 Simulator
23. MSD Digital DIS-4 ignition
24. MSD 8.5 wires
25. Performance Plugs
26. Optima Yellow Top Battery
27. NOS Custom Nitrous System
28. NOS Purge Kit
29. NOS Bottle Heater
30. Mallory Window Switch
31. WOT Switch
32. PCM Tray
33. New Alternator
34. RT 3" off-road DP (have to see how the turbo DP works)
35. RAT 3" exhaust
36. 3 Gauge A-pillar pod
37. 2 1/16" Auto Meter Carbon Fiber Gauges
-Air/Fuel Ratio
-Boost
-Transmission Temperature
38. 2 5/8" Auto Meter Ultra-lite Gauges in Cubby
-Fuel Pressure
-Nitrous Pressure
Transmission:
39. Triple Edge Performance street/strip transmission
-Input shaft
-Single chain
-Torque converter, stall still TBD?
40. B&M Transmission cooler
41. MSP Transmission Pan
Sell list GTP:
1. JMB 4" FWI and replace with stock.
2. Throttle body heatshield
3. TOG Headers
4. DHP Custom PCM (by Charles years ago)
5. Intense PCM
6. RAT exhaust tips
7. Stock headlights, with clear corners and 5000k HID bulbs
Misc. parts to sell:
1. Stock manifolds and TOG flex
2. 04+ spoiler
3. 04+ exhaust tips
4. 97-03 air baffle
5. (2) early 70s Formula hoods
6. Lumina hood vents
7. Levoc shift knob.
8. Etc.
Parts still needed:
1. Front and rear stainless PLOGs (GTP)
2. Engine cross braces (Regal)
3. Gen 3 M90 (Regal)
4. Spare tire cover, etc. (Regal)
5. 99+ coolant reservoir (Regal)
6. Gen 3 complete IC (GTP)
7. Polish blower casing (GTP, maybe ported as well depending on $$)
8. Paint engine and transmission (GTP)
9. M90 bypass electronics (GTP)
10. Tuning (GTP)
That's my abbreviated list of the plan so far. Started the tear down today. Not alot done, but a decent start for the little time I had.
Day 1
