Thread: Z7 Turbo Kit and proper boost
Results 1 to 20 of 33
  1. #1 Re: Z7 Turbo Kit and proper boost
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by mountaineerjeff View Post
    ^^^+++10000
    prixs arent fast and 12s arent fast either. and i still see an average stock grand prix with nothing but a turbo still running mid 13s at best.
    the OP is talking about running 9psi, any turbo that is efficient in that range, is too small for the 3.8. to be efficient you would need to go twin turbo like the 3000gts. and just run twin 11b's
    he also asked for the best/safest setup, not the one with the most power.
    POWER
    INEXPENSIVE
    RELIABLE
    now pick 2, since you arent going to be fast, then you might as well be cheap and reliable. easiest way to do that, is use the system he bought, run wastegate pressure and be done with it.
    z7 kit if your running mid 13's the car has major issues.
    prixs arent fast
    Wheres the troll spray when you need it http://www.youtube.com/watch?v=XKM3uRDSnlo
    http://www.youtube.com/watch?v=9aiXV...eature=related
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. what are the proper oil pressure readings
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-02-2010, 06:11 PM
  2. Proper Coolant Filling Procedure?
    By TronCarter in forum General Tech Discussion
    Last Post: 04-20-2010, 07:11 PM
  3. Proper way to seafoam 04+ S/C?
    By dirtmaster88 in forum 04+ Specifics
    Last Post: 01-11-2010, 04:32 PM
  4. Proper Alternator to purchase for 04 GT2
    By proofinlife in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 11:48 PM
  5. Proper gap for plugs
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 08:15 PM
