Thread: I looking to improve my dd
Results 1 to 9 of 9
  1. #1 I looking to improve my dd
    TN
    As the title states,I have 2000 gp gt and im looking for which turbo would be the best for a dd.
    As this is typed, I am leaning towards the z3 or z7 from zzp since they offer to install and tune.
    I have heard alot of bad news of thier tunes so I have a few questions I wish someone would answer
    1 What tuner dose zzp use hpt or dhp and do they lock them I got a answer its not locked and uses a hpt tuner
    2 dose anyone have advice on tuning to avoid problems that zzp tunes have often bought
    3 Is anyone running a zzp z3/z7 kit tune with/without any problems
    88 fiero formula l67
    04 ninja
  2. #2 Re: I looking to improve my dd
    No turbo kit is good for a DD on these cars...
    Do you have a built transmission for the power? Your probably going to need it if you drive with a heavy right foot.
  3. #3 Re: I looking to improve my dd
    TN
    A trans upgrade from triple edge would be included
    What are the problem points other than trans problems
    04 ninja
  4. #4 Re: I looking to improve my dd
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Soviet View Post
    The owner.
    After upgrading transmission you just have to keep the car on low boost if your looking to make it last long as a daily driver. Just the basic turbo kit alone should give you plenty of power for a dd fwd car. All you're doing is switching to a more efficient power adder and putting some more hot piping in the engine bay. As long as you dont raise the boost and are able to scan the car, you should be fine. If your putting in a cam you either need to have some good mechanical/tuning skills or have $$$$ and another backup car at all times.
  5. #5 Re: I looking to improve my dd
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    a z3 or z7 kit should be fine for a dd just run a good ic and dont run to much boost and you will be fine
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: I looking to improve my dd
    Quote Originally Posted by nascartech View Post
    wut.
    No.
    Comparing the Z3 and Z7 kit is like comparing a GenIII to a GenV...way different.
  7. #7 Re: I looking to improve my dd
    wut.
    No.
    wasnt comparing i was was just stating either choice will be fine if boost is kept lol and a ic is run just depends on how much u wanna spend on a kit
    sold 97 GTP stock
  8. #8 Re: I looking to improve my dd
    Jan 1970
    Maquoketa, Iowa
    wut.
    No.
    Not necessarily. One of the things I like about the z7 is the wastegate is located on the crossover, easier to get to, but that comes with a set back, you still only have a 2.5" dp. Now on the z3 kit the location of the wastegate is on the rear manifold, but it is open dump, which when that turbo spools up and the wastegate opens it becomes more like a 3" downpipe.
    Think of the z3 kit as a cheaper kit because of less fabrication needed to make it. You wont see much difference until you get in the 500's whp or above so it's probably safe to say neither kit is far superior to the other when it comes to hp per dollar.
  9. #9 Re: I looking to improve my dd
    TN
    Thanks for the help,Almost all the time it would be set to very low power.
    I never plan to cam it for fuel reasons,but have considered rockers.[What problems could rockers cause, fuel and damage wise].
    At last is there a way to do a conversion on a pcm that is programed with a hpt to be able be programed by a dhp.
    04 ninja
  1. How to improve acceleration
    By GTPcompG05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 02:04 PM
  2. improve motor
    By Pkorn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2010, 02:21 AM
  3. how to improve fuel economy?
    By bradford82 in forum General Tech Discussion
    Last Post: 02-01-2009, 09:01 AM
  4. how do i improve my gas mileage
    By biggmman in forum General Tech Discussion
    Last Post: 10-11-2008, 08:04 PM
  5. Improve Performance
    By NSUstud in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 09:43 AM
